Well, I'm making my first system after buying pre built computers for a few years and was hoping to get some advice from some PC veterans. My budget is £700 and below is my build I've decided on.
Case -- Thermaltake VA3000BNA Tsunami Dream SuperMidi Aluminium Tower
CPU -- Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB)
Motherboard -- Abit Fatal1ty FP-IN9 SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard
Memory -- GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Graphics Card -- BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
Hard Drive -- Hitachi Deskstar T7K500 320GB SATA-II 16MB Cache
Optical Drive -- NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter
Fans -- (2x) Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan
CPU Cooler -- Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Power Supply -- Corsair HX 520W ATX2.2 Modular SLI Compliant PSU
Well there it is. Anyone had these parts and had problems or is it a fairly solid build? Could I spend less in one area and more in another? Anything bottlenecked? Thanks in advance for any replies.
