Futuremark released a new patch for the 3DMark03 benchmark suite. Read more
In preparation for this summer's Olympics, China has just opened the world's largest airport terminal in Beijing. More than 50 million people will scamper through this terminal which is nearly two miles long and has 120 gates along with 73 aircraft parking spots. Read more
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
A new critical threat to Apple's OS X operating system has surfaced that could allow attackers to compromise a system without any user interaction. Read more
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
Tom's Hardware Forums »
Homebuilt Systems
New System Build »
[New System Build] Building a new system I have some questions
| Bottom | |
| Author |
Thread : [New System Build] Building a new system I have some questions
Profile: stranger
More Information
I am looking to build a new system, I am interested in overclocking but unsure about it or how to do it. I would like to go as far as i can using a koolance 1100 watt liquid cooling system.
Related Product
Profile: stranger
More Information
ANYONE???
Profile: Forum Veteran
More Information
If it was shorter, I think people would respond to it. Way to long. Your topic says you have questions. Where are they? Don't bother with the server board. It's like $300-400. Are you gonna run 2 chips for a total of 8 cores? I see ASUS hasn't updated the bios to support Barcelona. Give them some more time. BTW, Phenom will come in as AM2+, not Socket F for the server board. No contest. The best AM2 overclocker is 590 SLI. If you're serious about SLI or overclocking, get one. I have mixed feelings about the M2N32-SLI Deluxe Wireless. I owned one, but it was unstable when overclocked. ASUS might've fixed it with bios. I'd look at EVGA 590 SLI. Again, if you overclock, you get the 5000+ Black edition. Period. Now the most important thing for the AM2 platform is memory. Get as fast & tight-timing memory as you can afford if you overclock. At least Cas4. Ballistix is perfect, but the rebate has expired. Message edited by akhilles on 10-24-2007 at 02:15:34 AM |
Profile: Eternal Poster
More Information
Also your build is so completely out there that it's tough to know where to start........
Profile: addict
More Information
Drop the water cooling and get a quality aftermarket HS and fan (ask others). Don't get the server board. Wait a week and get a single 8800GT. Get 4GB RAM. Try the 750W PSU, there is no conceivable reason to get a 1200w model. You shouldn't spend more on the board or PSU than on the processor. |
Profile: stranger
More Information
The questions were more about the Asus L1 mobo and quad/octa-core possibilities. My
Profile: stranger
More Information
Ok so lets just keep the water cooling call me stuborn. question: what are your
Profile: stranger
More Information
Questions:
Profile: stranger
More Information
Message edited by dfg on 10-24-2007 at 10:14:17 AM |
More Information
You were right Phenom FX is Socket F. Only 2 will be out. The rest will be socket AM2+ (backward compatible). Differences between the 5000+ & 6400+: http://products.amd.com/en-us/Desk [...] aspx?id=39 The major ones are 65nm (5000+) vs 90nm (fry your eggs) & 72'c vs 63'c (max safe temp). Both are unlocked. One overclocker took 5000+ to 3.7Ghz on air. On H20, it's easy. I'm o/cing my 5000+. The only limits right now are heat & multiplier (up to x13). The 590 SLI has like any multipliers. Ok, basically: 200 x 13 = 2600 HTT x multiplier = cpu speed. Overclocking is not that simple on AM2. There's a ram divider. Take my o/c for example: 317 x 10 = 3170Mhz CPU This is a compromised overall speed. Find the max HTT (FSB) mobo speed, max GHZ cpu speed & max Mhz ram speed. See how important the ram is on AM2. Micron D9 is the best. With OCZ 800mhz RAM, I couldn't get that fast. Just give us a shout in the o/c forum when you want to o/c it. My suggestion: EVGA nForce 590 SLI AM2 (don't ever install ntune which will cause instability after months of use) Crucial Ballistix 2 x 1GB PC2-6400 (yes, rebate is back) This just in. Your favorite board will be AM2+ compatible after a bios update. http://www.asus.com/news_show.aspx?id=8305 If you can wait a month more, there'll be more AM2+ boards from MSI, Gigabyte & DFI. I have already seen the boards. Tri-crossfire. Not your thing. So 590 SLI is what you want. You can throw the Phenom at AM2. Just a few features will be missing. The only major socket upgrade will be in late 2008/early 2009 - Socket AM3. You put your other parts together & post the list again. Message edited by akhilles on 10-24-2007 at 03:14:44 PM |
Profile: addict
More Information
And drop the water cooling. What happens when the cooling leaks and fries your MB processor, and video card? If you get a quality fan/heatsink and case, you fans won't die. |
Homebuilt Systems
New System Build »
