Hello everyone. First post here. I searched the forum looking for answers to these questions about a new build and did find some clues but thought I'd ask them here for clarity (for me)
I'm starting a new build for christmas for my boy (13) with a budget of about $600 (monitor / HDD / optical from old one)
I appreciate that intel are producing the better chips these days but at my price point I don't think theres much of a difference and I've never had a problem with AMD products. He's likely to work on assignments (10%) and play games (40%) surf the web (50%).
I'm considering the following main components;
x2 6000 ($160) - presumably to drop in price as soon as Phenom hits
X1950Pro ($130)
2x1Gb Crucial Ballistix Tracer PC6400 ($55)
cheapish mobo - but not super cheap ($60-70)
Case - mid tower cheapish ($50?)
PSU - 400w? $50?
My questions are;
1) Assuming I use an old 160Gb HDD, how big of a power supply am I likely to require. I'm leaning towards a Thermaltake 430 or 500W model or maybe Antec 380W.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
2) I'm concerned by the heat a little. Would I be better off with the slightly slower X2 5600+ - I'm a little confused but got the impression that the memory I bought will work better with the 5600. How can this be when the clock speed is 200MHz weaker?
3) Windows. I don't see a big enough advantage in Vista at this time so I'm thinking XP will do. If I buy XP Pro can I install it (legally) on other computers in my home? Is there really no point in 64 bit versions?
I'm actually a Linux user so I don't know a whole lot about MS products. The last one I owned was Win98.
4) Is 2 GB enough should we decide to switch to Vista at a later date?
The last PC I built was an XP2100 so I am a bit out of touch with current hardware.
I appreciate any replies
X1950Pro ($130)
PSU - 400w? $50?
My questions are;
