The same thing happened to my Geforce 3 ti500 - The fan stopped working and whenever I tried to play games every minute or so it would freeze for a few seconds. As a temporary fix I just stuck a case fan inside next to my graphics card and it worked great. I actually ended up using it like that for over a year until I upgraded. Though if you don't have one lying around it'd be just as easy and probably better to get a VGA fan like vip said.
7600gs is a good card. Ether buy a cheap replacement for your fan/heat sink or buy a new video card. If your going to buy a new video card post ur psu specs, rig specs and budget please.
If by any chance you are using Linux - there is a bug at the moment in either Ubuntu or Suse (not sure which) where the ATI X800 models (and maybe some others) are having their fans maxed out all the time.
I read about it one or two weeks ago when playing around with Ubuntu. I'm sure you have checked it for dirt, obstruction etc.
Let it die a slow painful death today - replace it tomorrow...it's old. I have an X800pro and can't wait to start again next year. Good Luck.
If you take the current fan off - maybe that will give more clearance for your other air to hit the cooling components..
Message edited by a_dude on 11-03-2007 at 03:45:25 PM
You swap out the fan and heatsink....unless you can find another fan for that heatsink(not easy to do, but the screws are under the blades, you turn then slowly you will see small screws that hold the fan in).....
If that is too much of a pain(worried about breaking the card and wasting the money for a heatsink....), then a new card is the best option....
Message edited by nukemaster on 11-03-2007 at 05:31:07 PM
i am gonna toss together a quick guide for you.....just give me a sec
EDIT
I sure as hell hope you are on another computer
may be easier to just use zalmans own guide...
its not hard...
Clean you gpu core with q-tips and rubbing alcohol then apply thermal compound and spread it thinly with a clean credit/bank/ect card.(clean the end of the card with the rubbing alcohol...)
Install as per instructions below check the installation movie...there are 2 sets of holes for different card types
Note: i had to offset the ram sink a little....not like the card needed then anyway... dont forget the little rubber washers and to plug the cards fan in....since the card no longer powers it, you have to plug the fan in yourself..
EDIT
its not hard...
dude, not trying to be mean, but thats disgustinly dusty...
why you dont just go to a paint shop, and buy one brush and clean your computer?
that much ammount of dust is dangerous for your computer
A paint brush" can cause ESD and is not a good tool to clean out your computer with. And no that is not a dangerous level of dust for a computer. you should have seen my old system after 3 years of not cleaning, in a house with two dogs, carpet and seated on the floor
dude, not trying to be mean, but thats disgustinly dusty... why you dont just go to a paint shop, and buy one brush and clean your computer? that much ammount of dust is dangerous for your computer
Hows this?
or how about a smokers computer?
When i clean my server i will give you a nice pic
A friend of mine said that dust is like a protective coating for the computer parts(not seriously but he said it) It does get cleaned about every 2-4 months anyway....
Message edited by nukemaster on 11-04-2007 at 05:37:20 AM
OK guys, I bought the fan, and I have ONE quick question that the video/manual does not cover.
The last step is providing power to the fan. It says to use the attached dongle and attach it to the 4 pin connector. Is this the SAME 4 pin connector I use to attach to my graphics card? I mean doesnt my CARD need that power? Or does this take the place of it? OR do I attached it to the SECONDORY 4 pin connector and still attach the other 4 pin connector TO my card?
