Tom's Hardware Forums » CPU & Components » CPUs » Regarding the CPU & RAM bus speed
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Regarding the CPU & RAM bus speed
Toy-like people make me boy-like
Profile: stranger
More Information
Hi all,
I am in the process of building a new PC (not for games purposes, just some multimedia and internet tasks), and I have a silly doubt regarding the processor+chipset+RAM memory combination.
Right, the stuff that I have chosen is:
- Motherboard with chipset Intel G33 Express, with system bus running at 1333/1066/800 MHz
- Processor: Intel Core 2 Duo E6750 with with system bus running at 1333 MHz
- RAM Memory: 4 GB (2 set of 2 GB) at... 800 MHz??
Ok, and this is my doubt: as far as I know, and in order to avoid potential bottlenecks, both the CPU and the RAM should be working at the same bus speed, that is 1333 MHz ((pls correct if I am wrong).
The thing is that the RAM at 1333 (DDR3) is extremely expensive (at least here in Spain). But the curious thing is that in almost all the reviews and CPUs comparatives that I have checked (including the test in Tom's Hardware), almost all the systems that include Intel Core 2 Duo processors are configured with DDR2 memory at 800 MHz... is there or not potential risk of bottleneck because the CPU and RAM running at different speed?... Am I missing something?...  :??:
Thanks all for your help.
PS: apologies for my poor English  :ange: .
Related Pr oduct
Profile: Honorary Poster
More Information
A lot of people get confused by this so don't worry. CPU's run quad pumped which means they send info 4 times per clock so a CPU with a 1333FSB is actually running at 333x4. DDR (Double Data Rate) RAM sends info twice per clock so in order to run 1:1 with your 1333FSB you would need DDR2 667 which when run in dual-channel is running at 1333. The reason most opt for DDR2 800 or higher is for overclocking because with RAM that speed you can run your CPU up to 1600FSB before you need to start overclocking the RAM.
Take my setup for instance, I have a E6300 overclocked to 1600FSB and DDR2 800 running 1:1 with the CPU. For you I would just look for inexpensive, quality DDR2 667 RAM.
I know your not from the US but just to give you an idea what to look for this http://www.newegg.com/Product/Prod [...] 6820146112 is a great product and very inexpensive after rebate
and this http://www.newegg.com/Product/Prod [...] 6820220095 is another one which is good and has slightly better latency.
Message quoted 1 times
Message edited by ausch30 on 10-26-2007 at 08:50:38 PM
http://i192.photobucket.com/albums/z311/AUsch30/badge_wtp_02_3001.jpg
It is the mark of an educated mind to be able to entertain a thought without accepting it.
Aristotle
More Information
Don't buy DDR3 RAM (Unless your motherboard absolutely can't handle anything else). DDR2 is just as good w/o the hefty price tag. Just buy some PC6400 or DDR2 800 (as stated above) and you'll be fine.
Profile: Faithful Poster
More Information
400fsb cpu 200fsb memory
works great i run one just like it! i think its 3.4ghz?
this is a 1:1 ratio so there is no latency - some call it a 2:1 but cpuz shows 1:1
the main thing is you want the memory to be half the cpu - true 1:1 is hard to achieve and provides little performance gains and most cases you pay more for less.
for example a stock 1066 chip with 1066 ran has a lower bandwidth due to the 5-5-5-15 latencys then the second example below:
2nd example:
so if you have 3.37 (1.41-1.42v at full load) ghz e6600 at 1500fsb you run you memory at 750mhz and lower the latency's - maybe
4-4-3-8 ran at 750mhz runs great stock - super-talent at $80 you get a memory bandwidth of 6800-7200 @2.05-2.1v
i use this example since i build these all the time!
Message edited by dragonspra yer on 10-26-2007 at 11:21:48 PM
More Information
i checked my systems
6750/g33 in silverstone microatx box 2 raptors in raid0 250gb storage and game drive.
memory cooler and chip set fan added to the gigybyte mobo - asus are better and much easier to oc. but this mobo seems more stable with vista issues.
my cpu is 3.4ghz 425fsb memory is 850mhz
the ram is mushkin 4-4-3-10 at 2.1v 5-5-4-14
Vfsb is max Vcore 1.4375
Profile: nimble knuckle
More Information
If you're still confused by the excellent advice above,
here's how to simplify these concepts:
On Intel systems ...
800 means one thing for the Front Side Bus and
800 means a different thing for the memory bus
because the Northbridge has 2 busses:
one to the CPU and one to the RAM.
Let's start with RAM:
DDR2-800 means an effective clock rate of 800 Mhz;
but, the "frequency" of the RAM clock is only 400 MHz,
because "DDR" means Double Data Rate:  data is transmitted
twice for every tick of that memory bus clock.
And now for the CPU:
A rated FSB of 800 MHz means a raw bus speed of 200 MHz,
because the Front Side Bus sends data 4 times for every tick
of that CPU bus clock.  That's just the way that Intel chipsets
and Intel CPUs are designed to operate together.
Thus, our workstations here have a very common setup:
200 MHz "Bus Bpeed" x 4  =  800 MHz "Rated FSB" and
400 MHz "DRAM frequency" x 2  =  DDR2-800 .
And, because 16 bytes are transmitted for every raw tick
of the DRAM clock, or 8 bytes transmitted for each effective
tick of the memory bus, 400 x 16 = DDR2-800 x 8 bytes  = 6,400 MB/sec.
Thus, the memory bandwidth of our common systems is 6.4 GB/second
(i.e. 6,400 megabytes per second).
That is why DDR2-800 is also known as PC2-6400 i.e. 6400 MB/second.
If you download and install CPU-Z, you can standardize
on the measurements it reports:  on the above setup
the "Bus Speed" is reported to be 200 MHz and
the "DRAM Frequency" is reported to be 400 MHz,
for an FSB:DRAM ratio of 1:2.
Some folks like to refer to 800:800 as "1:1", but
that computation conflicts with the convention
used by the CPU-Z software.
It is highly recommended that we standardize on the
terminology reported by CPU-Z, because that
software is in such widespread use.
I hope this helps.
Sincerely yours,
/s/ Paul Andrew Mitchell
Webmaster, Supreme Law Library
http://www.supremelaw.org/
Message edited by supremelaw on 10-27-2007 at 12:23:33 AM
Profile: stranger
More Information
Wow, AUsch30... thank you very much for clarifying this... now it makes sense to me...
I think that, given that I will hardly ever try to overclock the system, I will go for the DDR2 667 RAM.
Again, thank all for your ideas...
Regards.
Profile: stranger
More Information
I hope this helps.
Sincerely yours,
supremelaw, thank you for the explanation... I have installed CPU-Z in my old system, and I am happy to say that both the CPU and the memory are running at the same frequency... and what is more important: now I know WHY and HOW this is possible...  :bounce:
Thanks all again.
it's great to find such a helpful folks like you guys.
More Information
>  Take my setup for instance:
Thus, you can see now why his numbers above are exactly correct:
1600 MHz FSB / 4  = 400 MHz Bus Speed
800 MHz DRAM / 2 = 400 MHz DRAM Frequency
Therefore,
FSB:DRAM ratio = 1:1 (using CPU-Z conventions)
If we reduce his FSB by 50%,
then 1600 / 2  =  800 MHz FSB / 4 = 200 MHz Bus Speed
and then
FSB:DRAM ratio = 1:2 (like our systems here).
Sincerely yours,
Message edited by supremelaw on 10-27-2007 at 12:39:46 AM
More Information
You're very welcome!
If you master that "800 MHz Sweet Spot" above
you can scale other settings in linear fashion.
Incidentally, there is nothing sacred about 1:1 ratios:
Intel-compatible chipsets can operate just fine
with other so-called "asynchronous" ratios like ours:
1:2  is asynchronous;  1:1 is synchronous.
Sincerely yours,
"Double quarter pounder"
More Information
yeah there's 0 problems ram is the last thing to worry about when it comes to bottlenecking
I wish everyone at my high school could be mature enough to talk PC hardware not just gaming.  You're unique... just like everyone else.
More Information
> One of you guys named supremelaw posted some posts in this thread:
> What I would like to know is:
“If you download and install CPU-Z, you can standardize
used by the CPU-Z software.”
>  I don’t really get it if its 1:1 or not.
>  In CPU-Z it says its 1:2 like one of you are writing.
>  Because 1:2 sucks if that is what it says it is
Double Data Rate ("DDR" ) memory transfers data TWICE per tick of the memory bus clock:
thus, there is an underlying "memory frequency" which is HALF the effective data rate.
For example, DDR2-800 means an EFFECTIVE data rate of 800 MHz,
but the memory bus clock is really oscillating at 800/2  =  400 MHz.
Similarly, the Northbridge on all modern Intel chipsets transfers data 4 times
for every tick of the CPU bus clock;  thus, the underlying "Front Side Bus"
frequency is ONE-FOURTH the effective data rate of that bus.
For example, a "Rated FSB" of 800 MHz is divided by 4 to produce
the "Bus Speed" of 200 MHz, using CPU-Z nomenclature.
If the "Rated FSB" is 1066 MHz, then the "Bus Speed" is 266 MHz.
If the "Rated FSB" is 1333 MHz, then the "Bus Speed" is 333 MHz.
The conventions used by CPU-Z are recommended,
because that software is in such widespread use.
Sincerely yours,
More Information
>  Thanks for the quick answer and help but its still not clear for me if its 1:1.
>  I have INTEL c2d e4500 @ 800mhz bus with corsair pc6400 @ 800mhz
>  when one of them is 4x200 and the other is 2x400…
>  both is 800 when you add them together but that doesn’t mean that is 1:1 or?
Just download and run CPU-Z:
http://www.softpedia.com/get/Syste [...] PU-Z.shtml
A "Rated FSB" of 800 MHz / 4  =  200 MHz "Bus Speed" (using CPU-Z conventions).
This means that the underlying clock rate is 200 MHz between the CPU and Northbridge.
Corsair PC6400 DRAM has an effective data rate of 800 MHz, but
"DDR" is Double Data Rate, so the memory frequency is 800 / 2 =  400 MHz.
This means that the underlying clock rate is 400 MHz between the DRAM and Northbridge.
CPU-Z just happens to report the ratio between these 2 "underlying clock rates".
Thus, your "FSB:DRAM" ratio, as reported by CPU-Z, should be 200:400 or 1:2.
Yes, some people report a different ratio of 800:800 or 1:1, but
that is not the convention being used by CPU-Z.
Sincerely yours,
Add a reply
Google Ads
