Hello ladies
Here is the problem (and a breakdown of)
My mums PC went gahgahh while I was at school, came home to hear that it had flashed up an enormous error and then turned off (thats all I got!)
So I thought hmm this should be interesting and proceeded to turn it on, only to be faced with, after BIOS and screen telling me Windows didn't work haha last time, a black screen.
So I started in safe mode to find that it was freezing on MUP.sys
Having seen this problem before on my brothers PC I plugged the disk into mine and ran a chkdsk /r on it.
What fixed the problem last time did not fix it this time.
So, after Googling the problem, I decided to try removing or disabling any hardware one piece at a time. This did not fix it. GRR
Anyway, I then tried using my XP ISO to repair it. It froze while loading a file at teh start called "SCSI disk". So I got another and this time it worked. I say worked, I mean got me to teh menu where I could choose what I wanted to do. I chose repair, and it deleted all the files it needed to. Then restarted. BAD
So, I put the HD back in my PC and ran a full surface test and file integrity check. It froze my PC, though I can't prove its that, because I have a poor wireless adapter that often freezes Windows (Google "WPN111 driver freeze" haha).
It's in their now plotting its next evil move.
MUP.sys is a networking file:
http://www.file.net/process/mup.sys.html
On a bit of a noobie site but OH WELL GET OVER IT.
Specs of my mums system: (mine in siggy)
Athlon 3000+
1gb DDR400
ATi Radeon X300
40gb ST3400012A HDD
DVD ROM
ASUS K8N4-E
XP SP2 (it was/is an integrated ISO, I'll try and find another)
Homebuilt BTW.
I'm usually the one helping people but I'm not having much luck this time. Anything, googling, flashes of genius is appreciated.
Cheers babez.
Athlon 3000+
1gb DDR400
ATi Radeon X300
40gb ST3400012A HDD
DVD ROM
ASUS K8N4-E
Homebuilt BTW.
Cheers babez.
