Tom's Hardware > Forum > CPU & Components > Sound Cards > Please help with onboard sound card
Forum CPU & Components : Sound Cards - Please help with onboard sound card
Hi everyone,
I have Creative - Inspire 5.1 5200 speakers.
MSI 975X Platinum PowerUp Edition which has the: Realtek AL882M onboard.
I downloaded the latest drivers for the sound card from msi and configured the system to 6 channels, but I have 2 problems :
1) There is no sound coming out from the center and subwoofer.
2) The sound is not smooth, it sounds pretty bad.
Thanks in advance!
Sponsored Links
If you are running Windows XP, you need to run Windows update for a patch concerning HD audio. Once that is installed you should probably re-install the sound card drivers.
I generally have had better luck with the drivers from the Realtek web site, rather than any that come on disk.
Reply to tlmck
- 0 +
I can't find that patch, can you please give me a link?
Reply to orbarya
- 0 +
The way I found it was to run Windows Update in the web browser. It showed up under the hardware update section.
Reply to tlmck
Do you have the speakers plugged in correctly into your motherboard? Somewhere in your onboard sound configs there should be a sound test that will play sound out of each separate channel. Try running that and see if it works.
Reply to smokedyou911
- 0 +
i have an ibm thinkpad r40 which has a realtek AC97 soundcard which i cant get to work ever since i reinstalled the OS. i have downloaded the drivers but it still doesnt work. any ideas???? anyone??
Reply to vegas15
There are 745 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
