How many system restore points should I keep?
Windows XP Professional is set to monitor my system drive and allocate 12% of it's space for system restore.
I have a 150GB hard drive, and I think 12% is too much space to reserve for restore points. Keeping too many restore points on my hard drive slows down virus-scanning and disk defragmentation.
Can someone please tell me about how many restore points I should generally need to keep in windows XP Pro, and also about how many GB of space is generally required to save that number of restore points?
- thanks
5 answers Last reply Best Answer
More about system restore points keep
  1. it's upto your need, 2 or 3 is ok.. .. i have enabled system restore on C:drive only..
    you can also change the amount of space to be used for system restore by going to properties of My computer & then system restore tab.. from settings you can fix the desired size..
  2. I have system restore enabled on my C drive only also.
    But approximately how many gigs of space does it take to store 2 or 3 restore points?
    (I know this might vary from user to user, but just a ballpark figure...)
  3. Best answer
    may be 2 Gigs of space is enough ..
    here some details about system restore.
  4. Your answer helped me out manojgj. -- Thank you. :)
  5. Best answer selected by Beep_Beep_Yeah.
Configuration System Restore Hard Drives Windows XP
