I have mixed up the power supply units that I have, and am not sure which is the correct one for my Maxtor OneTouch 4 PLUS 500GB external HDD that I purchased recently.
Can anyone please help with informnation on the make and spec of the AC power supply unit that I was supplied with?
The one I have that is most likely to suit, I think, is made by APD model WA-24C12N, about the size of a mobile phone charger, and is rated 12 Volts, 2A DC output.
I would appreciate your help on this. The details are not available on the Maxtor web site. In the meantime, I am unable to use my HDD
kind regards,
Jill
Message edited by JillB on 06-02-2008 at 12:47:51 AM
This is kind of an old message, but I had the same problem of a lost PS. I figured out the power specs (since they are NOT written on the drive case for some oddball reason ) and figured I'd post them for others!
You can always either find an old PS laying around, or you can just hit radio shack or something and get a new one, they're pretty cheap.
The power supply specs for the Maxtor One Touch 4 (and indeed most external USB hard drives) are:
Thank you, thank you. I had thesame problem as JillB, when I misplaced the PS. Then jruddock gave the specs (12Vdc/+tip/18W) for a 500G unit. I suppose that my 1TB unit will use the same 12V PS, right?
BJtheDJ@swbell.net
Although jruddock did give you some great advice and specifications, one of the most important parts is the amperage that your hard drive will draw while under full load. So to answer your question, the adapter may or may not be different between your 2 hard drives. It depends not only on the hard drive size, but also the interface (USB/eSATA/Firewire) of the hard drive. The typical 500GB Maxtor® OneTouch III with USB will use a 12V DC/2.5A power supply with a center tip positive barrel connector. Your 1TB unit may draw more amps than that, and need a larger power supply.
P.S. For those who said check RadioShack, good luck! Most of their A/C adapters do not exceed 1.5amps. You might have better luck with someone like www.12Vadapters.com , I know I did.
I'm trying to find the adapter also for the Maxtor One Touch 4. All I could find is that it needs 100-240 vac and 47-63 Hz AC .
I'm seeing them on Ebay but I can't tell if it will fit in the hard drive. Where can I get an exact replacement?? WE NEED THIS THING FOR OUR DJ BUSINESS!!! ALL OUR MUSIC IS ON THIS HARD DRIVE. Please help! Thanks!
I don't have a reply for you but, am in the same boat. I moved to WA. from Hawaii an can't find my cords either. Did you manage to get one? if so, can you direct me to where I can buy one.
These should be very close to max, Normally will be slightly less.
Add 2/3 Watts (0.25 A) for interface (kind-of-a wag)
Should be OK with any brick over 1.5 A.
as Long as => 1.5 Smps, With that in mind, MOST Important is +/- Orientation.
Most enclosures use an onboard regulator. The reason is that some "bricks" do not provide a regulated output. The output voltage is specified for rated current. As the load current decreases, the output voltage increase. Some 2.5 Amp (12V) bricks may have an output of 13 -> 15 Volts when used at halve rated current. So using a 2.5A/12V brick for a 12V/1.25A load will only make the regulator work "Harder". This is seen as extra heat. (Same-same if regulator is in "Brick"
Message edited by RetiredChief on 09-02-2009 at 10:06:18 PM
You might have better luck with someone like www.12Vadapters.com , I know I did. My PS cord went out last night and this site has all the adapters that you will need. You will definitely find what your looking for here.
I have a Maxtor OneTouch 4, 500GB and it does indeed take a 12V, 2amps, tip positive power supply.
Manufacturers really ought to write this spec on the casing. I've had the same problem when storing things separately from their power supplies - something I no longer do.
My only reply is, grumble, grumble .... This is a common problem that results from LACK OF GOVERNMENT REGULATION.
I've encountered this problem with many electronic devices for the last twenty years and I've destroyed at least one device when I didn't realize that not only is the voltage important but also the amp rating!
Often the voltage and amp requirements are not even ON THE DEVICE ITSELF and you have to search the internet or rummage around in your file cabinet for the manual.
This information should be placed on both the adapter and the electronic device on pain of the death penalty. (Well, maybe twenty years in prison would be sufficient.)
Grumble, grumble....
