I always disconnect power to my PSU by turning off my power manager when I am done with my PC for the day. The first time I boot the PC after re-applying power to the PSU the PC will boot for a second, sound a post beep, turn off for a second, turn on a second time, sound a post beep for a second time, and then boot normally.
Any subsequent cold boots only post once as long as I do not disconnect power to my PSU. Why is my motherboard double posting after disconnecting and re-applying power to the PSU?
My X38-DQ6 also leaves my optical mouse light on when I turn off the PC if power is still available at the PSU.
+5v is present even when "off"
I can't find the link to power supply operation at the moment that explains this and the yellow on/off wire.
Is the motherboard battery installed?
For sure, P35 chipsets double boot after Bios changes. I don't know about X38, but I'm inclined to think Intel would do them the same way since they were created back to back. So perhaps the battery on your mobo is a little low and when you re-apply power from the PSU it thinks something changed? Or perhaps the loss of 5v from when your PSU is fully off is having that effect.
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground? Or the ones who illegally pay vendors to not support the first group?
Reply to Scotteq
The mobo battery is installed and I do not lose my BIOS settings when I power off my power manager. A co-worker just built a GA-P35-DS3L and his mobo does not do this.
Message edited by rossb on 11-16-2007 at 08:26:51 PM
Just got to ask ...
Your "power manager", does it have a pass-through (always on) AC connection that the pc is connected too?
Is the battery in upsidedown? (I never took notice if this could be done)
My power manager does not have an always on socket. I plugged my PC directly into wall current (no power manager) and used the hard switch on the back of the PSU to turn it completely off. When I turned the PSU back on and hit the power button on my PC the mobo posted, turned off, turned back on a second later, posted again, and then booted. All subsequent cold boots only posted once (normally) as long as I did not remove AC power from the PSU. I also tried letting the PC sit for 5 minutes with the PSU getting AC power before attempting to do the first cold boot after a power loss. It still double posted.
I did not check the battery but it has to be inserted properly. I am not losing my BIOS tweaks.
Message edited by rossb on 11-16-2007 at 09:24:06 PM
I just tested my X38 and I noticed that the double post after being disconnected from AC power only occurs when I overclock my Q6600. It does not happen when I run the stock CPU FSB Frequency and Memory Multiplier.
When I run the stock clocks it only posts once and boots right up after being reconnected to AC power. I think Scotteq was right, it appears to be updating the BIOS when I cold boot after losing AC power while overclocking my CPU.
