New Build
Q6600
P5K DELUXE
8800GTX
WD 750 GB SATA
CORSAIR 620HX
all the above im getting from my uncle as a gift...
im buying
ZALMAN 9700NT 2300 BAHT
ASUS 18X DVD WRITER SATA 1300 BAHT
CM 690 3000 BAHT
i wanted to know what ram i should get
1 GB PQI DDR2 800 1300 BAHT
1 GB KINGSTON DDR2 800 1700 BAHT
WHICH IS BETTER
IM ON A SMALL BUDGET AND THE PQI IS CHEAPER
BY THE WAY $100 IS 3300 BAHT
EDIT*
I LIVE IN INDIA AND THEREFORE ITS MORE OR LESS HOT AND HUMID ALL YEAR ROUND 35* CELSIUS IS NORMAL
AND I WILL BE BUYING IN THAILAND
THANKS
Q6600
P5K DELUXE
8800GTX
WD 750 GB SATA
CORSAIR 620HX
im buying
CM 690 3000 BAHT
WHICH IS BETTER
EDIT*
THANKS
