Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Gigabyte Motherboard problem
Forum Motherboards & Memory : Gigabyte - Gigabyte Motherboard problem
I've got a new Gigabyte GA-965P-S3 Intel P965 socket 775 motherboard that won't boot up. All components below are new.
What's installed: Intel Celeron D 352 3.2 GHz Processor
ATI All-In-Wonder X600 Pro PCI Express
SEAGATE 160GB SATA HD
Corsair XMS2 2GB (2x1GB) DDR2-800
At power up, the CPU fan spins, the ATI cpu fan spins and two cooling fans spin.
This continues for about 30 secs and then shut down.
Nothing appears on at all on the Viewsonic 17" LCD monitor.
No graphics, no bios, no video card ident display, nothing at all.
Any suggestions as to where the problem lies?
Sponsored Links
What power supply are you using? All the power connectors plugged into the motherboard?
Reply to cfvh600
- 0 +
580w Sunbeam power sply/
Reply to cmangle
- 0 +
Does your case have a speaker (beeper) ?
You should reseat your RAM, graphics card and processor.
If that doesn't help (still no POST/ error beeps) one of this components is most likely dead or the motherboard doesn't detect the RAM or CPU.
EDIT : What revision is your motherboard ? Maybe it needs a bios update.
Also some 965 boards had issues with certain RAM types if I remember correctly.
Message edited by Andrius on 11-17-2007 at 11:40:45 PM
Reply to Andrius
- 0 +
Be sure to connect the case speaker lead to the board to get some beep codes.
Reply to o1die
hi all
My hardware is :
Intel Core 2 Duo 2.00 Ghz
Two Kingston 1 Gb ddr2 each at 800 mhz
MSI Geforce 8600 GTS 256 mb
I am having exactly the same problem that was posted as mentioned below, no beep, no graphics, My hardware are perfectly working on other motherboards.
Plz HELP ASAP !!!
Reply to tahirawan11
See if you can boot it up outside of the case on the foam pad. If so you are grounding on your case.
Reply to SpinachEater
There are 1020 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
