Well... All seems to work ok but I wanted to get your guys input because when I'm running OCCT it keep "crashing" after 20mins, which I assume it means its unstable.
My temps seem to run fine but maybe my Vcore or RAM is to blame. Call of Duty 4 seems to run just fine and haven't experienced any other problems until i tried OCCT. Maybe I'll try Prime 95 and see what kind of results I get. Also I bumped up my Vcore to 1.3250 and I'll see if it runs smoother that way.
Any help would be appreciated. Let me know if you guys need more info.
Update: Probably wasnt enough time but I did run Prime 95 for 50mins and no errors found. Also just ran OCCT just CPU mode and still got the Crash signal.
-Just set my CPU frequency and DRAM to 1:1 as the Overclocking guide states (333:667) but I noticed that my RAM post as PC2 4300 instead of 6400. However I just noticed that in the Overclocking guide 'graysky' system also posts at PC2 4300. I suppose this is normal on a P5B Deluxe? But running this way made OCCT crash in 2mins. I'll run Prime 95 over night and see what happens.
