First attempt at building PC (under $700) Need advice
I am building a computer for the first time and have spent a considerable amount of time looking into hardware and trying several builds. It has been mind boggling with all of the specs, capatibility issues and prices. I'm trying to build a system that I can upgrade with more RAM and a better video card later, as I'm trying to stay under $700. I am going to use the computer for basic internet browsing, and games like Warhammer Online. I'm not looking to OC the machine, I just want a reliable computer for basic needs.
I am going to use a SATA HD and an IDE DVD/CD drive. Will this cause any problems/issues? I have been looking at this site too for advice and I'm so glad I found it. The people here really know what they are doing and this site should be supported by all the hardware companies, because I know it has given me the nerve to consider building my own machine when I would not have otherwise.
Thank you,
DigitalBliss
2 answers Last reply
More about first attempt building under advice
  1. https://secure.newegg.com/NewVersion/WishList/MySavedWishDetail.asp?ID=6415472
    Update Thermaltake Tsunami VA3000BWA Black Aluminum ATX Mid Tower Computer Case - Retail
    Model #: VA3000BWA
    Item #: N82E16811133132
    Return Policy: Standard Return Policy
    In Stock
    $119.99 -$10.00 Instant $109.99
    Update GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail
    Model #: GA-P35-DS3L
    Item #: N82E16813128059
    In Stock
    $94.99 $94.99
    Update MSI NX8600GT-T2D256E OC GeForce 8600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Video Card - Retail
    Model #: NX8600GT-T2D256E OC
    Item #: N82E16814127286
    Return Policy: Limited 30-Day Return Policy
    In Stock
    Mail-in Rebate
    $109.99 $109.99
    Update Thermaltake TR2 W0070RUC ATX 430W Power Supply - Retail
    Model #: W0070RUC
    Item #: N82E16817153023
    In Stock
    Mail-in Rebate
    $39.99 $39.99
    Update Intel Core 2 Duo E4500 Allendale 2.2GHz LGA 775 Processor Model BX80557E4500 - Retail
    Model #: BX80557E4500
    Item #: N82E16819115031
    Return Policy: Processors (CPUs) Return Policy
    In Stock
    $129.99 $129.99
    Update G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model F2-6400PHU1-1GBNR - Retail
    Model #: F2-6400PHU1-1GBNR
    Item #: N82E16820231085
    Return Policy: Memory (Modules, USB) Return Policy
    In Stock
    $34.99 $69.98
    Update Western Digital Caviar SE WD800JD 80GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    Model #: WD800JD
    Item #: N82E16822135106
    In Stock
    $42.99 $42.99
    Update Sony NEC Optiarc Black IDE DVD-ROM Drive Model DDU1615/B2s - OEM
    Model #: DDU1615/B2s
    Item #: N82E16827101131
    In Stock
    $17.99 $17.99
    Update Creative Sound Blaster SB0570 Audigy SE 7.1 Channels PCI Interface Sound Card - Retail
    Model #: 70SB057000000
    Item #: N82E16829102002
    In Stock
    $29.99 $29.99
    Update Arctic Silver 5 Thermal Compound - OEM
    Model #: ARCTIC SILVER 5
    Item #: N82E16835100007
    Return Policy: Consumable Items Return Policy
    In Stock
    $5.99 $5.99
    Update ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
    Model #: ACFZ7-PRO
    Item #: N82E16835186134
    In Stock
    $34.99 -$15.00 Instant $19.99
    Subtotal: $671.88
  2. Ditch the AS5. Not needed. The Freezer has thermal material.
    Swap that mobo out for this for less with the same chipset:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813127031&Tpk=ABIT%2bIP35-E
    You can go with e21x0 cpu for less.
    2x1gb ram would be a good investment in the long run:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565
    I would look at an AMD CPU & MOBO combo since you're not overclocking & the AMD is the best bang.
New Build Computer Systems Product
