Seagate PCB swap help!
Last response: in Storage
Recently my external Lacie hard drive failed to power up. It had a slight burnt smell to it.
I cracked it open and inside was a Seagate Barracuda 7200.10 320gb.
So I ordered a new Barracuda ( identical ST3320820A ) with the intention of swapping out the PCB which I did. The hard drive is now spinning but I can't get the bios to recognize it.
The only difference between the two boards is the firmware. The old one is 3.AAC and the new one is 3.AAE. Could this be my problem and if so, can I fix it?
More about : seagate pcb swap
If you had a compleat new HD why did you not just use the whole thing?
The way you are doing it will never work with your old data (new controller firmware). You now most like need to format the HD.
Befor you changed the controller you should have checked to see if it would still spin. If it did still spin you should have run SpinRite 6.0 on it.
Related ressources
First off, the use of SpinRite would have been a huge waste of time. Before doing anything, I strongly suggest you consider the value of the data to you. Any attempts you make now can and will most likely increase the cost of professional data recovery services. It is my recommendation that, if your data is worth $300 or more, you get take advantage of the free evaluation that most data recovery labs offer.
If you want to do the recovery yourself, you may get lucky with getting a PCB that is an exact match. But, the damage could be more severe than just the PCB and could also be with the head assembly and/or the SA tracks. If so, you'll need tools that will far exceed your budget.
Have fun!
Flawed procedure at the very start. Too late for OP, but for others who might read this thread ....
OP reports burned smell from an external drive, opened the case and found a Seagate HDD unit inside. First step should have been to identify whether the failure was in the case, or in the HDD:
(a) Mount HDD inside a computer as an internal HDD, test to see whether it works there.
(b) Since OP bought a replacement HDD of the same type, IF the first test above says the original HDD does NOT work as an internal, then mount the new one in the old case and test whether that works.
After these THEN we know which component needs to be fixed.
The first thing the OP should have done was to remove the damaged board and examine it for obviously burnt components. The usual culprit is a 12V or 5V TVS diode which can simply be removed. The drive will work without it, but it will no longer have overvoltage protection on the affected supply rail. You need to be sure that your PSU is OK.
These URLs should help you identify the components:
http://hddscan.com/doc/HDD_from_inside.html
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
You can replace the 12V diode with an SMBJ12A, and the 5V diode with an SMAJ5.0A. Both are available from Farnell, Mouser, Digikey.
