I downloaded the CRYSIS DEMO the other day and it looked amazing even on my pny 7900gs on medium settings. Then I went to play the next day and the graphics don't exist. There is picture, but whether or not you can call it graphics or not is debatable. People are invisible, mountains are everywhere, but can be seen through top left corner of screen is dark etc. WTF? This doesn't happen during normal usage, just when I try to play CRYSIS, so I figured it must be the DEMO, which I reinstalled to no avail. Any help or advice, thanks.
Check some other games you like, play them through a bit make sure you havent got a hardware problem. Try altering the res, bring it down to something low like 800x600. If that fails try latest nvidia drivers. Then I'd say check youve got correct monitor drivers. Make sure you havent got any sh't running in the background before you try to load up.
don't be running things like a virus scan, web browser, windows media player, etc... don't really worry about all the small background tasks in task manager, unless they are taking up too much of your memory or cpu, in which case you need to tweak some options using the msconfig tool. Sounds to me like you should try getting the latest drivers for your card at the nvidia website. If you already have the latest drivers, reinstall them. If that doesn't work, reinstall the game. If that doesn't work, google search for the latest direct x updates from microsoft and install those. If all of those things don't work, let us know and we'll take it from there.
also, tell us more about what you have. vista or xp? 64 or 32 bit? Latest drivers? Also, make sure you are not running any programs while installing the game. This could potentially mess up the installation so just let your comp. sit while it installs games, if you haven't been doing this already.
Message edited by rayzor on 11-07-2007 at 07:58:03 PM
Turn off AA in your driver settings and make sure the AA is off in the in game settings. I upgraded drivers too select the beta option from the nvidia site. That fixed all my probs. I had the same thing on 7800GTXs.
I've seen graphic anomalities when people are overclocking...if so, turn back your normal configuration.
If you're not overclocking, your hardware may be running hot (or faulty)...you can find out by downloading programs that monitor temperatures...such as NTune for your 7900GS.
If its a software issue then try reinstalling your videocard drivers with the latest NVidia drivers.
This is what I am running:
AMD X2 5200+
GIGABYTE 590 SLI bios s5_f7
PNY 7900 GS (NO OC) -Latest drivers off of nvidia- 163.75_forceware_winxp_32bit_english_whql
2 250gb seagate hard drives
------------------------------I was thinking of the immortal words of Socrates who said, "I drank what?"[/Chris Knight]
You know what ole Jack Burton says at a time like this? Ole Jack says...what the hell[/Jack Burton]
I'm not sure if your still having this problem, but I have a evga 7900gt ko and was also having this problem. I actually turned AA on 2x and that fixed it....give it a shot I guess.
According to your post you are running the 163.75. The current Beta Drivers for Crysis are 169.04 which are what you get when you download them from the link I just gave you.
You do not need to re-install the demo, just the drivers.
Can you hear the sarcasm lol!!!
------------------------------Windows XP MCE & Vista 64-bit (dual boot)
XFX NFORCE 680I LT SLI w/ OCZ Platinum 4 Gigs Dual DDR2 @ 800MHz
Intel Core 2 Quad Q6600 @ 2.4GHz w/ ChillTec Thermo Electric CPU Cooler
MSI NX8800 GTX & X-Fi XtremeGamer Soundblaster
Reply to Alex The PC Gamer
AMD X2 5200+
I don't have the wrong drivers, those are the ones I just downloaded!!!!
I reply:
Quote :
OK, I'm going to be real nice.
You reply:
Quote :
was the one on my computer.
What do you think is some sort of chat room where things take place in real-time?
If you're running the 169.04 Betas then you've got the right ones. Re-install them and see if it helps. You do not need to re-install the demo.
I am a system's builder and I have built two systems specifically for Crysis. These are 100% CLEAN- FULL installs of windows Vista Ultimate (32bit). My main system is using Nvidia's 680i chipset on an EVGA board and I have two 8800GTX EVGA cards running in SLI. My processor is an Intel EE X6800. Memory is Corsair 8888C4 (2GB) which is on EVGA's QVL approved list. Power supply is MORE then enough. I installed Vista on ONE 150GB WD Raptor hard drive so as not to have RAID problems with Vista. All I did was install Vista (full version), all updates from Microsoft (and of course all motherboard drivers) and then I installed Crysis, Bioshock, the new Call of Duty 4 Demo and Stalker. The video drivers I installed were 169.04 downloaded from EVGA's web Site. Active X is the latest. All games installed pay at the very HIGHEST settings with absolutely no problems whatsoever----EXCEPT Crysis. On my 1920 x 1200 monitor, I have to drop to Medium settings to get Crysis to run at all. This is even after I perform the Crysis system check and it recommends the settings to be VERY HIGH. If I turn on AA, the game will not even start. I then removed the 169.04 drivers the proper way in Vista---and then I always use driver sweeper in safe mode to clean up. My next step was to install the 169.02 drivers---same thing, all games work very well EXCEPT Crysis. Next step was to try older drivers. The current drivers on Nvidia's site are the 163.75 for Vista 32bit. With these drivers I could actually play the game in HIGH settings, but if I turned on AA to ANY setting, I could not even start the game. There is absolutely nothing on this system that is overclocked or tweaked in any way. My PC-Pitstop score is 4785 with no problems detected. Defragmentation was performed after each driver install. Every game worked on the very highest settings---except for Crysis. My second system is not as powerful, but fully capable of playing Crysis. Same thing---all games play very well except Crysis. The 163.75 drivers work much better then the 169.** drivers, and I can't turn on AA AT ALL and even start the game. All I am presenting here are the facts. I can not stress enough that I built these systems with Crysis in mind and I wanted a complete, compatible and uncorrupted setup. Considering the other games worked very, very well but Crysis would not, I can only make the assumption that there is a massive problem with this game. One last thing--I built a system for my Fiance'e who is not into gaming, but does quite a lot of video editing----so the system can handle that. No SLI, just a quad-core Intel, very fast memory (4 Gigs) and an ATI very high-end video card. RAID 1 also. I didn't bother installing the other games, but I installed the Crysis demo, and I downloaded and installed the very latest ATI drivers. SAME THING. I could play Crysis in high settings (but the game ran choppy) and could not even start the game with AA set. Medium quality setting worked best and smoothed out the game. By the way, Crysis recommended--even for this system, very high settings. NADA I don't know what else to say or do. After everything else, I installed 3DMark06 on my main system. On a totally untweaked system---my scores rocked! Crysis will not work for me--that's all I can tell you and I am getting too old to try to find solutions. If it doesn't work "out of the box" I no longer want to fool with it. I am tired of this.
I am afraid there is no miracle answers to your question. Not that I can confirm that but I don't think the demo of Crysis enables you to use SLI. Regardless, you may not be able to play this game at very high settings although you should play this game at higher settings than most of us given you have 8800gtx in SLI (WOW!).
You may want to see what people get in FPS when the actual game comes out as only then will people be able to put their benchmarks with SLI system configurations.
Alex
Message edited by Alex The PC Gamer on 11-11-2007 at 07:03:22 PM
My PC:
Striker Extreme
E6600
2GB Corsair DDR2 800 at 4.4.4.12
8800 GTX
SoundBlaster X-Fi Fatal1ty XtremeGamer
5.1 Sound
WinXP SP2 with all patches.
Latest version of DirectX9c
Nvidia 169.04
Antivirus disabled.
Game set at Highest setting.
Benchmark_GPU.bat in Crysis gives an average of ~30 frames/sec.
When using the DX10 hack I get ~20 frames/sec
I wouldn't wonder if Alex is correct in that the Crysis demo is not SLI enabled. Crysis requires lots of RAM and Vista is wasting lots of RAM when playing games. If you don't believe me check this article at Anandtech: A Messy Transition (Part 2): Windows XP, Vista, and the 2GB Barrier
Link: http://www.anandtech.com/cpuchipse [...] spx?i=3044
Hopefully MS fixes this in SP1 for Vista as they says it fixes performance issues.
Its the game. Its buggy. I contacted XFX and they have heard this repeatedly. I had similiar issues. It IS NOT A NVIDIA DRIVER ISSUE AT ALL. =IT IS CRYSIS DEMO=
Dissapointing gameplay with outstanding graphics. Why can't we have both...
yea i got the same problem 1 day after i got the demo..... all good finished it.... next day things are like invisable but with an outline..... x1950 pro..... med settings.... 45 frames at night averge and 31 averge at day... it did run good at first.....
Dont understand how people think a game can run on one set of drivers and not another unless the beta drivers they are going on about have some special suport for some of the DX10 stuff in Crysis.
Either way its not relevant as the op is running XP and i am playing it on a ATI card also in DX9.
Can anyone answer this for me please as im a bit confused about it.Do i have the wrong end of the stick here or what?
Oh and by the way mine went septum over sturnum when i turned X2 AA on! go figure i guess,
I recon its the game as well.
Mactronix
SLI doesnt work at all, it only uses 2 cpu cores at max and it NEVER hardly uses them! tests have been done it's like 30 - 60% on 2cores max. All that physx being done on the GPU rather then using the CPU's of quads.
Nvidias and ATI's drivers are still young, too, though. But basically DW about its performance yet, itll improve over time, it'll still be extremly demanding but itll pay off to have an overall gd system rather then just a gd GPU.
------------------------------Na na na na na na na na HATMAN!
Reply to Hatman
My PC:
Striker Extreme
E6600
8800 GTX
5.1 Sound
Nvidia 169.04
Antivirus disabled.
That's why you don't run 32-bit Vista. Anyone who actually builds a system and installs 32-bit Vista on it, in my mind, is retarded. Heck I put 64-bit Vista on my parents computer I built for them just because its the same price and fully compatible. I figure better to plan for the future.
YEP - YEP - YEP ....Crysis is at the moment very buggy in it's demo/beta form . LET'S HOPE THEY FIX IT !! And when installing new drivers ..... make sure you use a program to completely wipe all the old drivers out !
And quoting this " That's why you don't run 32-bit Vista. Anyone who actually builds a system and installs 32-bit Vista on it, in my mind, is retarded. Heck I put 64-bit Vista on my parents computer I built for them just because its the same price and fully compatible. I figure better to plan for the future.
I think good old tom's hardware did a comparison and 64 bit did no significant boost at all ! RETARDED ???? I think not .... Anandtech has been wrong many times and alot of people read old outdated tests . How can anyone or site check the specs on a pre-released demo or beta and call them facts ???? Every beta sucked I ever ran and have ran many for bucu years .... always many issues and bugs .... that's why they call them betas .... we test them for free and they reap the benefits .
