Tom's Hardware > Forum > Storage > DVD/CD Writers > New DVD Writer Problem
This is the problem I am facing:
http://i29.tinypic.com/2egfa7a.jpg
Mine is a LG DVD Writer.
Please help in solving it.
Thanks in advance.
Sponsored Links
If the drive is empty, i don't see a problem..
Reply to doormatderek
Put a disk in?
Mine looks like that with no disk also.
You need to be clear on the problem, not show a pic and say fix it.
Reply to roadrunner197069
Thanks for the response doormatderek.
This image is of a LG CD/DVD Writer.
I think the file system should have been unknown or NTFS, not raw and type should have been DVD Drive.
Whenever I insert a DVD inside it doesn't recognize it as a DVD.
I always get this message:
F:\ drive is not accessible.
Incorrect function.
Message edited by ashman007 on 06-07-2008 at 07:48:22 PM
Reply to ashman007
XP or Vista?
You might need a driver.
Load up a free trial of Cyberlink or other DvD decoder.
XP doesnt have DvD support built in out of box.
Mine is a XP.
I always use a free version, whichever I get from download.com (mostly 30 days) to write DVDs.
I might have the CD (misplaced?) still which I got when I purchased this DVD Writer.
I will load the driver again.
Thanks again for the responses.
Reply to ashman007
There are 1115 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
