Tom's Hardware > Forum > Overclocking > CPUs > E2180 overclocking problem
Forum Overclocking : CPUs - E2180 overclocking problem
I have some problems with the OC on the msi p35 neo 2 fr.Each time i try to get over 316 Mhz FSB(no mather the cpu multiplier or FSB/memory ratio or the cpu and memory voltage) the bios puts automatically the NB voltage and SB I/O power on high voltages(NB 1.45 v SB I/O 1.8 v values that the bios says that are not recommended and unstable).For example I've tried 333x9 on which the system gives overclocking error and won't POST.What could be the problem?
------------------------------ MSI P35 Neo 2 FR Bios version 1.4
Intel E2180 @2Ghz
MSI 8600GT OC 256MB
2x1GB GEIL 5-5-5-15 DDR2 800
Sponsored Links
Did you leave the voltages on auto? If so, do it manually.
Also did you change the system memory multiplier to 2 ( or 1:1 fsb to ram ratio)?
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
- 0 +
Yes.I've tried all multipliers but without luck.
Reply to sam_t
- 0 +
I don't have auto option on voltages just on dram.
Reply to sam_t
There are 758 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
