Hi, I am building a much needed new midrange gaming rig. So far what I thought of getting is:
■PCU Q6600 G0
■DDR2 A-DATA Vitesta Extreme Edition DIMM Kit 2048MB PC2-6400U CL4-4-4-12 (DDR2-800) (ADQVD1A16K2)
I know the A-Data are not well-known in the U.S but I've read some great reviews about them (I'm in Europe)
■XFX GeForce 8800 GTS 500M, 640MB GDDR3, 2x DVI, TV-out, PCIe
■PSU Corsair VX 550W ATX 2.2
■Case Sharkoon Rebel9 Economic Midi-Tower
It is not a great case, but I plan on gettin a couple of Scythe S-FLEX 1200, 120x120x25mm, 1200rpm and it is cheap.
■Motherboard Asus P5k P35
This one I'm not sure about, I really like the Asus Bios, but if you guys know a similarly priced, better gigabyte mobo , I would get it. I don't plan on using raid or sli, but I definitely need the firewire port.
■Scythe Mugen (this is the Scythe Infinity with another fan)
Should I get the Thermalright 120 instead? I plan on OC-ing. I hope to get at 3ghz, from what I've seen it should be doable.
Any input is highly appreciated. Thank you all in advance.
■PCU Q6600 G0
