i just built a computer. it has Ultra 120 Extreme cooler with Noctua NF-P12 fan. the cooler vibrates about 5-20Hz. the vibration is visually noticeable. i can feel it with my finger. it stops if i hold the cooler. it doesn't make any audible noise.
i concern that prolong vibration will cause physical damage to the computer, and that heat paste will flow away. i use arctic silver 5.
what do you think? do i need to do something about the vibration?
