I got one issue. I got a cabnit where I store my computer which has no room for air flow. The issue bigger than that is I only got a 18 inch gap to put the Case. I currently have this case
http://www.newegg.com/Product/Prod [...] 6811119047
Which says the height is 17.2 and I got about a half inch to spare and I got the rubber feet off.
Please I would like someone to help me select a case that is good and will fit into the needed area.
Also PLEASE if you see anything I have listed that doesn't sound right or you would improve on without going up drastically in price please let me know. Any help would be greatly appreciated.
Your using Pricewatch so I would imagine you plan on buying where ever parts are cheapest correct? If so I would strongly suggest checking out ResellerRatings http://www.resellerratings.com/ and check up on the companies you plan on buying from.
------------------------------ It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
Reply to ausch30
Your case should be fine. It's the cabinet that may need attention. Is it open at the front or rear? If not, you may have to drill some holes at the rear for airflow. Pricewatch is fine, but you may want to check the particular co you're dealing with using reselleratings.
