Sign-in / Sign-up
1066mhz kingmax or 800mhz Kingstone/Corsair
  • Memory
  • DDR2
  • Kingmax
  • Corsair
  • Product
Last response: in Memory
November 22, 2007 3:05:17 PM
Hi Guys!
Which one is better?
DDR2 Kingmax 1066mhz 2x1GB
DDR2 Kingstone 800mhz 2x1GB
Price is same and i dont know how much the brandname counts.
the CPU would be E6750
More about : 1066mhz kingmax 800mhz kingstone corsair
a b } Memory
November 22, 2007 3:07:55 PM
Hello mate:)
well DDR2 800 doesnt have alot of differenec with DDR2 1066, what are the timings of those RAMs ?
November 22, 2007 3:33:50 PM
both of them are CL5
i found a third competitor:)
Geil 2048MB 800MHz Black Dragon Dual /2x1024MB Kit
this is the same price as well and its CL4
November 22, 2007 3:54:35 PM
What mobo?
November 22, 2007 4:14:12 PM
ASUS P5K or GigaByte GA-P35-DS3L
I Cant decide that even, any recommendations?
November 22, 2007 4:39:29 PM
If its the same price, I'd get the Geil Black Dragon ram. It nothing else, it looks nicer and has a great name.
November 22, 2007 4:53:44 PM
In either case you should check the QVL compatible memory on the manufacturers website and try to get RAM that is on the list. Understand that the 2G packs have additional numbers and letters on the model number. Here is the Gigabyte list motherboard_memory_ga-p31-ds3l_1.0.pdf . I'm using Crucial Ballistix 2GB DDR2 800 on a P35-DQ6 and it works flawlessly.
November 22, 2007 5:59:15 PM
Well, Kingmax is 1066 on default, with 1.8V (I believe) - that looks promising. Others could probaly be OC-ed to that speed, but would need more voltage.
But in the end, I don't think it makes much difference.
November 22, 2007 7:21:13 PM
so 1066mhz for Kingmax worth more than the Geil Kit's CL4 timeing insted of CL5?
November 22, 2007 9:23:12 PM
Kingmax probably can also do 4-4-4-12 or better at 800MHz...
Do you intend to run FSB synchronously with the memory (1:1)?
If so, latencies may be more important for you.
There is a nice article about frequencies vs. latencies at http://www.xbitlabs.com/articles/memory/display/core2du...
a b } Memory
November 23, 2007 4:10:29 AM
DDR2 800 doesnt have much difference with DDR2 1066 so go with the
DDR2 800 RAM which has lower timings(Geil 2048MB 800MHz Black Dragon Dual)
November 24, 2007 11:53:06 AM
Thanx for the info
a b } Memory
November 24, 2007 3:52:05 PM
No problem mate :)  glad i could help u :)
