Hello there. I've been wanting to upgrade from my AMD3000+ for awhile now, and I think it's finally time. I haven't really been "in the loop" of all the new hardware coming out, I used to be, so I know what I'm doing, just don't know all this new crap. And I've decided to go with the Duo Core, even though I haven't used an Intel since my old Pentium2 233.
This computer would be for general use, but I want it to be able to run some serious loads ok. Games, maybe some compiling, ect. I've looked around, and have a few questions, and a start of two builds, one I think I will eventually buy. My budget is limited, trying not to break $900 (was $800, but ahh.. no self control)
The first one is more expensive, but I would be willing to pay an extra $100 or $150 if there was a big enough difference. (Prices are from newegg)
C2D 6550 (169.99)
ASUS P5K-VM LGA 775 Intel G33 (119.99)
ASUS EN8600GT OC GEAR/HTDP/256M (144.99 -10.00 rebate = 134.99)
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (129.00)
Seagate Barracuda 320GB 7200 RPM SATA 3.0Gb/s (84.99)
LIAN LI PC-60BPLUSII (129.99) (oh how I'm tired of my shuttle, very nice and convenient to move, but not convenient to work on)
That's 768.95, add a $30 DVD Burner, $10 for some cooling compound, a little over 800. Now all I need is a PSU. I do plan on OCing this, but not a whole lot, something very stable.
For my 2nd build I downgraded the CPU, Mobo and RAM to
C2D E4500 (128.99)
GIGABYTE GA-965P-S3 LGA 775 (99.99)
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (119.00)
Changes to 697.95 + $40 for burner and compound, 740.
Now I have been reading around, and lots of people say the E4500 can achieve the speeds of the higher 6xx0 CPUs, which if that is the case, why not get it. Also, regarding the RAM, is there much of a difference between the 800MHz and the 1066MHz, the price difference isn't very much. For the video card, I think (please tell me if I'm wrong) that with a system like this the video card should be able to run new games with ease. I know the 8800GT is only $90 more, but if the 8600GT will run things fine, I do not want a more expensive card. I have no idea what kind of PSU to get, I don't want 800W if it isn't needed, could someone please recommend a range or a model for this setup.
Money is a pretty big factor, but I get so excited about all this computer hardware I can't help myself sometimes.
Thanks,
Bill
C2D 6550 (169.99)
C2D E4500 (128.99)
Thanks,
Bill
