Tom's Hardware > Forum > Homebuilt Systems > New System Build > Advice building a photo editing system
Forum Homebuilt Systems : New System Build - Advice building a photo editing system
Sponsored Links
uhhh right you didn't post ANYTHING
------------------------------ It's a theater of love stories.
Reply to itotallybelieveyou
Sorry, I made a mistake the first time.
I would like to build my first system, I will use it for photo editing mainly, with Photoshop Cs3 and Lightroom.
Could anybody give me a hand?
Thanks
Reply to Odin9977
Lots of RAM. 4 gigs minimum. At least a dual-core, quad if you can swing it. Photoshop will love you long time.
Reply to burntham77
RAM, RAM, RAM and some more RAM.
The modern MB and 64bit OS can handle 8GB. Might be overkill, but planning to go to 8 GB is a better strategy than just buying 4GB with no long term strategy. I would buy 2 x 2GB sticks with the plan to go to 8 GB if needed or desired. The 2x2 sticks will cost a little more, but allow you to bump to 6 or 8GB at a latter day with the lowest total cost.
The Q6600 is an ideal CPU.
------------------------------ I am old enough to be your grandfather.
It was born a Dell, it was made into a computer by StevieD
Reply to StevieD
There are 997 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
