Tom's Hardware > Forum > Overclocking > General Discussions > Is the same speed ram with a higher voltage better or worse?
Forum Overclocking : General Discussions - Is the same speed ram with a higher voltage better or worse?
I bought some ram from new egg, it was supposed to be 2.1-2.3 volt 5-5-5-15 1066 2 gig sticks, but I was send the same speed only 2.3 -2.5 volt type. Do I wanna get the lower voltage chips, or does it really matter?
Any explanation would help!
(GeIL evo one 2 x 2 gb pc1066 5s rated at 2.3-2.5 volts.)
Sponsored Links
Lower voltage for a certain speed is better as long as it is stable. Mainly because of lower temps and could increase lifespan on lower volts. If you ordered one with 2.1-2.3 certified and got 2.3-2.5 certified then call G. Skill and see if you can get the right ones
------------------------------ Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
- 0 +
Hmmm, okay, I think I will give them a call. The add says 2.1-2.3 volts, and the RAM they sent says 2.3-2.5 volts. Anyone else have an opinion on this? (They do have the double height heat spreaders!) I was under the impression that as long as you run it at its rated voltage. ::shrugs.:: I do have decent components! Need input!
Like... anyone else use the things?? Evo One 2 x 2 GB kits. Got 2 pair, hehe!
Reply to Lupiron
I agree with S77.
This post may help clarify things: http://www.tomshardware.com/forum/ [...] s#t1249881
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
- 0 +
Wow, that actually made sense. I guess I see what you mean. I will get on the phone and get the lower voltage ones as they claim. I wasnt thinking clearly enough on the subject. The lower the voltage at whatever speed, the better quality of ram it must be, because anyone can add voltage to gain a lil speed. Its called over clocking, imagine that!
Thank you very much!
-Lupi!
Reply to Lupiron
- 0 +
Basically. ;)~
Reply to Lupiron
There are 905 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
