Tom's Hardware > Forum > Overclocking > General Discussions > OC problem with 4x1GB
Forum Overclocking : General Discussions - OC problem with 4x1GB
i have oc problem with 4x1GB... modules are supertalent pc6400 cl4 and identical.
with 2x1GB (any two and any channel) everything works with 400x8=3.2GHz cpu and 400x2.5=1000MHz@5-5-5-15@2.1 for ram or even more (1066MHz)...
IS RAM OC POSSIBLE AT ALL??? i try to increase memory voltage to 2.3V
333x3=1000MHz@5-5-5-15 works, but system is unstable!!
what do you think about 400x8=3.2GHz for cpu, and 400x2=800MHz@4-4-3-8@2.0v
is that fine combination, or somebody suggest something else??
Sponsored Links
sorry:
gigabyte ga-p965-ds4
intel core2duo E6600
supertalent pc6400 cl4 4x1GB
if oc is not possible what do you think about 400x8=3.2GHz for cpu,
Reply to ninoid
With more sticks of ram, it's harder to OC and you'll need more voltage. I like to set my memory multiplier to the lowest possible, which is 2, because in everyday application, you won't see the difference. Just get the timings as low as possible.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
- 0 +
i am going to stay on:
400 x 8 = 3.2GHz for cpu and
400 x 2 = 800 @ 4-4-3-8 @ 2.0V
can 4-4-3-8 go lower?? which voltages?
and does i need to increase voltages for fsb and mch
for my OC? i dont understand when i must increase fsb and mch voltages??
Reply to ninoid
I'm not sure if you have to increase your NB voltages, but if you are experiencing any instabilities, try increasing by .1v.
As for your ram, I don't think you can lower the voltages much more.
There are 1334 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
