Components:
PSU: Corsair HX 620
MoBo: GA-P35_DS3R
Chassis: Antec 900
GPU: 8800GTX
Hi all. I have some build questions about connecting the chassis fans to power , and also my 8800gtx to whatever power source I need to connect it to.
I have 4 fans on the 900 that I need connected, however my MoBo's 4pin connector is already being used by the CPU cooler and only has two more, 3 pin connectors - my fans have 4 pin connectors, and I think 4 pin molex connectors.. What I have done is connected the bigger 4 pin (molex?) from the fan, to a cable that runs to my PSU. What I want to know is why I can connect multiple components on the PSU's molex cable, it has a male/female connector on one piece that allows me to piggy back components...does this mean I can piggy back two of my fans onto 1 molex into my PSU? Does each rail supply enough power for that? I don't think I have enough connectors to my PSU otherwise (e.g. 4 fans, HD, GPU, DVD)., and I don't have a manual that details the power that runs through the rails.
If anyone can shed some light on this for me, and what kind of connectors I need to keep my eye out for to connect my GPU to the PSU I would really appreciate it because I want to finish up my first build - and I want to do it right!
Thanks everyone!
PSU: Corsair HX 620
MoBo: GA-P35_DS3R
Chassis: Antec 900
GPU: 8800GTX
Thanks everyone!
