My Fan Speed
My fan on my Heatsink is plugged in the Cpu fan plug on the motherboard ... i cant figure out how to put the fan over 1400 rpm ... i tried on bios but i didnt saw where i can raise it ...
there is any software i can use !?
2 answers Last reply
More about speed
  1. Did you disable an option like smart fan control or something?
    Try speedfan. Dunno how to use it though.
  2. If you disable smart fan it should max out. Stock intel fans run around 1900rpms
CPUs Fan Fan Speed Overclocking
