A keyboard activated with guitar sound!
Last response: in Applications
October 21, 2012 2:16:08 PM
Hello people!
I need help, it's for a competition with a prize at the end, but I don't even know where to start!
The main idea is that I want to be able to literally type on the computer with my guitar.
The more in depth explanation of that is that I want to somehow make my computer anylyse the sound my guitar makes,
and for every specific range of frequency (for every tone) to input a letter or any key on the computer.
Please help me cause I really want to win that competition, so I am gonna try hard to put that system together!
October 21, 2012 11:59:39 PM
What programming language are you familiar with? You basically need to identify the current major tone, and then translate that to keyboard input.
October 14, 2013 12:49:20 PM
You won't find ready solution (after all, the competition you're entering into is not for Googling, I suppose). But Google could be your friend to gather the pieces for solution based on Hardware "keyboard emulator"
Have a look at this http://mitchtech.net/arduino-usb-hid-keyboard/. It uses a (very user-friendly) microcontroller connected to your PC, and the software inside that controller emulates a keyboard. Now, find another piece of software for Arduino which listens to analog input (where you connect a microphone, or guitar pick-up), analyzes the frequency, and translates it into a key.
Good luck hacking!
October 25, 2013 4:22:56 AM
Good luck hacking!
Thanks a lot!
I really appreciate it.
It might be what I go for and I know other recommend me the same. Might be.
However.
You might have heard about the rocksmith and rocksmith 2014 games.
I was thinking to utilized the jack to USB cable they have already made and which works great.
So right now I am trying to get a hold of their developer team to implement what this thread is about, as a guitarcade game as they are called at least in rocksmith 2014.
I am not so sure about the success of that, but if not then I will still like to utilize the existing USB cable and will then 'just' need software on e.g. PC that detects this input and transform them to keyboard keys.
I might be able to on freelancer or similar or maybe a local university here, but more help will also be very appreciated.
