Tom's Hardware > Forum > Overclocking > CPUs > e8400 overclock to 3.6Ghz - problems
Forum Overclocking : CPUs - e8400 overclock to 3.6Ghz - problems
I'm trying to overclock my e8400 to 3.6Ghz. Just a nice sedate amount for me.
I have a strange problem that manifests itself whenever I hit this speed.
First I upped the FSB to 380 (380*9 = 3420MHz) and set the memory multiplier to 1:1 (760MHz DDR)
I gave the FSB a +0.1v tweak, and set the CPU voltage at 1.28v
The PCI-e frequency is set to 100MHz
I ran prime 95 (not for a huge amount of time, but enough to convince me the machine was not about to reset) and all seemed good.
I could then pull about 11500 in 3dmark06.
Now the problem.
When I increase the FSB to 400MHz for my 3.6Ghz clock I can run prime95 fine.
I had upped the CPU voltage a little more (in fact I've tried voltages from standard (fails) to 1.3v)
However when I run 3dmark06 the graphics seem to lag. The framerate is fine, and I will score around 12500. But the graphics stutter. It's as if half or quarter second chunks are missing.
For example, in the canyon ride test where the air-boat thing is coming along the canyon it's very jerky.
I've been watching the temps (using the motherboard utility) and they don't rise above 42 C.
Core temp tells me the cores are up at 62 C but I know this is bogus.
Anyone any ideas what is going on?
Message edited by jay_l_a on 02-20-2008 at 05:44:17 PM
------------------------------ GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2x 1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||2x 750Gb WD Caviar||Cooler Master Real Power Pro 750W||2x HD4870 512Mb(Crossfire)||HT Omega Striker 7.1
Sponsored Links
Wanna know what drives me nuts? I dont know if you are runnin' the tests after ya boot or what, but stupid pre fetch can do that to me sometimes. Though it doesnt effect whatever its doing, it looks like it does. As in, my mouse jumps around and freezes like that, though its not "really" doint it! And if I release a huge amount of RAM, like from prime 95s blend test and swap to a test that uses way less ram, pre fetch is at it again!
Oh, anyone know how to kill pre fetch? Damn thing trashes my Crysis!
--Lupi! (Ignore meeeee!)
Reply to Lupiron
- 0 +
Damn, Didnt even mention the other thing. Core Temps! Is your Bios up to date? I just opened a brand new p5k e with whatever bios, and my temps are funny too. Core temps are like 47 max under load, lol, but Tcase gets to 47ish. and I have noticed that core temps like to be about 14 c hotter. So its obviously detecting them wrong. But Idle, now thats funny... cores at like 32 and t case at like 36. yeah right! Check the bios, and get HWmonitor!
Then again, you could be on some cool liquid, and not get that hot!
--Lupi
Reply to Lupiron
- 0 +
Lupi,
not sure about the pre-fetch thing, but it seems to be consistent when I go over 385-390 MHz on the FSB. Can you explain what you mean by pre-fetch for me?
BIOS is up to date.
Maybe it's temp related. My mobo utility tells me I'm 25C idle and 40C load, running on air. Maybe these temps are wrong.
Jay
Reply to jay_l_a
Firstly, does your ram pass Prime95 blend test and memtest?
If so, what kind of PSU do you have?
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
- 0 +
Core temp is correct with the OC you're doing at that Voltage. I'm running 3.6 on my Wolfdale with 1.296v(per CPU-Z) and I'm running a 25C idle(Tcase, this is what your Mobo utility reports) and 35C idle under CoreTemp (which reports Tjunc1/Tjunc2) Under load in Prime95 it will peak at 70/71(Tjunc), but settle down after several hours and go into the 60s...and thats with me on an Intel HSF!!! Tcase for me peaks @ 60C, which is fine considering that throttling doesnt take place until 72.5C Tcase. 100% stable after just short of 12hours (overnight run) and i got 16,414pts on 3dMark06. im running the X38-DQ6 board, so i have better power regulation, so there may be a voltage drop on your PCIe bus that's causing the stutter. I wouldnt take too much stock in 3dMark "looks" because i average 230fps in HL2:Lost Coast and looks soo smooth that i can tell whoever made the flythrough didnt make a very smooth movement pattern at all :P
Message edited by serj on 02-21-2008 at 04:51:27 AM
Reply to serj
- 0 +
I ran the standard prime95 stress test, and checked the 'rounding errors' options as per the suggestion in the C2D guide.
I think the ram *should* be fine as I'm not overclocking it any. I'm running it at DDR-800 at 4-4-4-12.
My PSU is a cooler master Real Power Pro 750W, which should be more than enough for my single card set up.
Reply to jay_l_a
Relax the timings on the memory.
------------------------------ "Quad cores are only good for burning CD's"
Q6600 @ 3.3 | Xigmatek HDT-S1283 |
8800gts G92 512mb (756/1890/1044) | GA-P35-DS3L
Reply to Asian PingPong
- 0 +
The memory specs indicate it will fun fine at 4-4-4-12 at 800DDR
I can try relaxing them, but why do you suggest this? Do you think they are too tight.
Just a FYI
when I was running 333Mhz FSB and a 2.4 MEMORY RATIO (ie 800 at 4-4-4-12) I didn't have this problem.
Would prime95 not error if there was a prob with the timings?
Reply to jay_l_a
Hmmm, you're right, at at first I thought it may be because the volts weren't high enough to support that speed and timing consistently, but if you were running them before at 4-4-4-12 and 800 then its most likely not the problem.
Message edited by Asian PingPong on 03-03-2008 at 11:34:31 PM
- 0 +
I had the same problem and I fixed it by loosening DRAM TRFC if u have that on ur mobo mines a P5B Deluxe, it was on 30, 35 or 42 fixed it for me
Reply to Devriak
- 0 +
Devriak,
thanks for the info. What is the full name of TRFC? It may be called something else on my mobo. I believe I have all the timing options available to me, I just don't recognize that name.
Reply to jay_l_a
- 0 +
I have the same hardware you have Jay and I'd like to run my Wolfdale @ 3.6Ghz also, but I have this 1200Mhz Ram (Transcend) 5-5-5-15. Should I take it down to 800Mhz or leave it where it's at?
Reply to Kridian
- 0 +
Kridian,
I'd first try the 1:1 memory ratio (on this board it is described as 2.00B (you can also try 2.00D although the 2.00B seems more stable for me)
Then up the FSB bit by bit. I had to hit the 1.2875 Vcore setting to remain stable at 3.6Ghz. (400Mhz FSB)
Remember to run Prime as you go to ensure everything is stable.
then benchmark when stable at 3.6Ghz
THEN.
if you have DDR1200, try one of the 3.00 memory multipliers to hit your 1200DDR. However, you may get away with tighter memory timings with the 2x multiplier, so all you can do is bechmark and see which gives you better performance.
One thing I have discovered is the 1T command rate at 800DDR 4-4-4-12 doesn't seem to yield much performance increase in a benchmark, but games seem to be a little more responsive....
Message edited by jay_l_a on 03-06-2008 at 04:44:07 PM
Reply to jay_l_a
- 0 +
If I use the 1:1 ratio (2.00B), would I have to set my DDR to Auto or leave it at its 1200Mhz speed before the reboot?
------------------------------ GA-X38-DS4 (F2) | E8400 C2D | 4GB Transcend 1200Mhz | Zalman 9700 | Vista 64 | BFG 8800GTX
Reply to Kridian
- 0 +
The only things you need to worry about
1. Turn CPU Host Clock Control to ENABLE
2. Up your CPU Host frequency. A nice starting point might be to go from 333Mhz to 350Mhz REMEMBER YOU NEED TO MONITOR YOUR CPU TEMP to avoid damaging anything. If you get problems, check temps, check vcore (more vcore required for higher speed HOWEVER more heat needs to be dissipated)
3. Turn Performance Enhance to STANDARD
4. Set your PCI Express to 100 Mhz (you don't want this to rise as you up your FSB)
5. Set your System Memory Multiplier as I described EARLIER (ie 2.00B) You can tinker with this To Your Hearts Content once you get the basic setup stable.
6. As your ram will be essentially underclocked initially, take the tightest timings the manufacturer recommends.
SEE HOW YOU GET ON
also
http://www.tomshardware.com/2008/0 [...] _steroids/
http://www.legionhardware.com/document.php?id=717
http://www.diy-street.com/forum/sh [...] p?p=779228
Reply to jay_l_a
- 0 +
I realize that I didn't SPECIFICALLY answer your question.
So, Now I shall, and then We Will All Be Happy
You don't actually set the DDR speed AS SUCH.
It's a product of the FSB and the memory multiplier.
So using the 1:1 ratio your memory will be running at DOUBLE (DDR, remember) your FSB speed.
For example,
1:1 (2.00B) at 333 Mhz = DDR-666
5:6 (2.40B) at 333 MHz = DDR-800
1:1 (2.00B) at 400 Mhz = DDR-800
2:3 (3.00B) at 400 Mhz = DDR-1200
AND SO ON.
Reply to jay_l_a
- 0 +
My E8400's **** for the temps too..
CPU is at 21'c Idle...
Core 1 @ 42'c IDLE
Core 2 @ 42'c IDLE.
Whats that all about?
Reply to dev1se
- 0 +
Ok that worked out Jay. So if I go higher (400) then I would go down to CPU Voltage Control and add some? At what point did you decide to up the voltage on yours?
Thanks for the insight!
Edit: Yeah, it looks like Prime95 is leveling off the temperature at 42°C with the FSB at 350. I'll take a bit higher tomorrow.
Message edited by Kridian on 03-07-2008 at 04:22:09 AM
Reply to Kridian
- 0 +
Increasing the Vcore is not mandatory.
I decided to increase the voltage when my overclock was not stable past 385MHz fsb.
As the frequency of the CPU increases, it sometimes needs a little more JUICE!
If you have hit 3.6Ghz with no increase in vCore then you have a good processor.
Stress-testing will reveal any weaknesses in your overclock. Have you run prime95 yet?
Reply to jay_l_a
There are 814 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
