Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Help Finding a heatsink that fits ???? Thermalright Ultra-120
Forum Overclocking : Cooler and Heatsinks - Help Finding a heatsink that fits ???? Thermalright Ultra-120
hey guys i need help finding a heatsink that fits.
i have had bad luck with finding ones that fit in my motherboard.
i was thinking about getting a Thermalright Ultra-120 but i don't know if it will fit.
the heatsinks usually bump into the north-bridge or the heatsinks on the board.
my system:
(my first build)
d975bx2 -board
cm stacker 830
q6600
500gb sata
750w powersupply
2gb 800mhz twinx memory
evga 8800 gts scc graphics card
motherboard pic: http://www.intel.com/products/moth [...] 75xbx2.jpg
Sponsored Links
I'm not sure if the TRUE can fit, but it's designed to fit most performance board. The Arctic Cooling Freezer Pro 7 will probably fit.
Use a ruler and measure it to be sure.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
i don't think the Arctic Cooling Freezer Pro 7 is good enough to cool it and i will measure to see if it will fit
Reply to tetracore44
How far are you going to OC?
Newegg lists the dimensions for the heatsinks btw.
ill try for 3.0ghz
AC7 is good for up to 3.2GHz.
if i can go higher with good temps i will and i have had bad luck with cooling so i want to orer cool it if it will fit. also the ifx-14 my fit instead, is it any better than the True
The TRUE is the best. You might need to do some lapping though.
im a little weary of lapping
I agree. I believe it's flatter now, but you might come across one that requires lapping.
i think its my northbridge heatsink that gets in the way so what do you think about replacing it, any suggestions. my chipset is 975x.
also how can i tell if my mobo will allow me to overclock thanks
There are 466 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
