Hi, I currently have an Asus P5W DH Deluxe motherboard and have having some trouble overclocking past ~380 bus speed, so I'm deciding to get a new motherboard. I want one that'll be decent for overclocking the Q6600 to about 3.5GHz or higher and runs decent with a CPU only watercooling setup. I only know of ASUS to provide fans for the MOSFETs/heatpipes to keep them cool using a watercooling setup. Also, I don't care much for bundled games/software, so that won't make a difference. Also, I don't care much about the onboard sound, since I have a Creative X-Fi.
My requirements:
-P35 or X38 chipset (w/ support for Penryn CPUs)
-DDR2
-RAID support
-Overclocks Q6600 well (runs cool enough) with CPU watercooler
-Hopefully (not a requirment, but would be nice!) has FireWire and eSATA
So far I've been looking at the following ( with comments added [+]pro & [-]cons [~]not sure ):
-ASUS P5K-E/WIFI-AP
■+ one of the cheaper boards
■+ FireWire
■+ eSATA
■+ Voltage damper for quad-cores
■~ NB heatsink looks ok, could add a 40mm fan
■? Could I attach the ASUS fan from my P5W-DH on the MOSFETs heatsink?
■? Not sure on it's overclocking abilities with Q6600
-ASUS P5K PREMIUM/WIFI-AP
■~ price seems ok
■+ FireWire
■+ eSATA
■+ NB heatsink looks good, could add a 40mm fan
■+ Comes with 2 fans for the MOSFETs heatsinks
■+ Q6600 overclocking (from what I read) is pretty decent
■- I read this board had problems with HDDs and RAID, can anyone confirm!?!
-ASUS P5E
■+ Good price for X38
■+ FireWire
■- No eSATA
■? No voltage damper for quad-cores
■- X38 runs hotter than P35
■+ Comes with a fan for the MOSFETs heatsink
■? Q6600 overclocking
-ASUS MAXIMUS FORMULA
■- Price is starting to get high
■+ FireWire
■- No eSATA
■? Voltage damper for quad-cores (is there one?)
-GIGABYTE GA-P35-DS3P
■+ Price is nice
■+ FireWire
■~ No eSATA, but has SATA-to-eSATA bracket
■? NB heatsink looks ok, maybe add a 40mm fan
■- No fans for watercooling setup
-GIGABYTE GA-P35-DS4
■+ Nice price
■+ FireWire
■- No fan for watercooling setup
-GIGABYTE GA-X38-DQ6
■- Price is high
■+ FireWire
■+ Q6600 overclocking (from what I read) is about the best
So basically here are my questions and thoughts:
-Will the chipset remain cool enough with no added fan using a watercooling setup?
-Is is necessary/worth it to have an X38 chipset?
-Would the NB cooling be sufficient on the P5K-E & Gigabyte boards?
-I'm leaning towards the P5K Premium if it doesn't have RAID/HDD problems. Plus I'm an ASUS supporter/fan.
-To have hot swap eSATA capabilities on the Gigabyte boards, doesn't the onboard SATA controller have to be set to AHCI sine it uses the onboard connectors? But if I have it configured for RAID, would I not have hot swap capabilites on the eSATA ports?
Any help, advice, or other suggestions would be greatly appreciated!
-GWolfman
My requirements:
-DDR2
-RAID support
-ASUS P5K-E/WIFI-AP
■+ FireWire
■+ eSATA
■~ price seems ok
■+ FireWire
■+ eSATA
-ASUS P5E
■+ FireWire
■- No eSATA
■+ FireWire
■- No eSATA
■+ Price is nice
■+ FireWire
■+ Nice price
■+ FireWire
■- Price is high
■+ FireWire
-GWolfman
