My first question, so I hope this is the right section.
I have an ECS A780GM motherboard which has 5 SATA connections - I need 6. I used a PCI 2 port SATA card with 2 SATA DVD R/W's attached with no problem, but I now need to free up a PCI slot. So, I bought a PCI-e 2 port SATA card, similar to http://www.syba.com/Product/Info/Id/4
Installation no problem and all BIOSes updated successfully to the latest versions etc. BUT..... if I boot my system with any drive connected to the new card, I get a "load bootable media" error message. If I boot my system with NO drives connected to the new card, I can start XP as normal. SATA "hot swap" means I can connect drives after XP has booted but that hardly seems to be an ideal solution!
It seems that the new card is hi-jacking the boot order I have set in the motherboard BIOS and the motherboard BIOS seems to have no way of excluding the new card at boot time!!
Has anyone encountered a similar problem? If so, is there a solution?
