Hello all,
Need your guidance on putting a CAD PC together. I'm a CAD student and would like to build a PC workstation dedicated to CAD software. Autocad 3D, 3DSMAX, Revit, Inventor, others.....
I've been looking at the Dual CPU AMD socket 940 w/ the Opteron Italy 270HE, 275 WOF, or the 280. I've also been reading up on the TYAN and SUPERMICRO mobos. Video card, leaning toward the nVIDIA QUADRO 3000+ series. Stuffing these in the Antec P180B case.
I'm open to any and all suggestions from you experts out there. I haven't lock anything down yet. Any suggestion is great appreciated. Would a QUAD Core be better instead of two Dual Cores? Intel vs. AMD? XEON vs. OPTERON? Power supply recommendation? Antec, Enermax, Gigabyte (Odin), PC Power & cooling, Seasonic, etc.... Minimum power requirement recommendation? I figure that this PC will be number crunching intensive when in 3D animation.
This system will not be used for gaming. Strickly for CAD and 3d animation.
Thanks in advance for your kind support.
