i got a new 500gb harddrive and when i try and install windows xp on it from the boot with my other harddrive out it says "lmsbd(might not be right) not found please restart"
plese help my old harddrive is about to break.
You need to remove the old HD, set the new one to active and master, set BIOS to install from CD, then install. Once you're set up, slave the old HD and copy your data.
