Tom's Hardware Forums » Overclocking » 3D Chips » 8800GTS 512MB overclock speed ok?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : 8800GTS 512MB overclock speed ok?
You tell me what I do.
Profile: Ancient Poster
More Information
I have a Inno3D 8800GTS 512MB currently overclock at 755/1835/2070.I have done volt mod on it jus standard cooling and voltage.Pair with Q6600@3.2Ghz 3Dmark 06 about 16000 point.does that sound normal for this spec?
Related Pr oduct
Master-de-bater
Profile: Eternal Poster
More Information
Yeah. A 3.89GHz Q6600 with a 8800GTS 512MB 811MHz core gets around 17,000+.
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
More Information
alright thanks alot.but what temp range is safe for this card on stock cooling with automatic fan.
Master-de-bater
More Information
Under 85C for load. You might want to set the fan speed manually.
More Information
any good setting for the fan when setting it in manual?i mean balance between speed and noise.i dont want it to "shout" about in my room
Master-de-bater
More Information
70% is good. Just keep edging it upwards until you can't stand it.
More Information
you are one helpful person!i gotta ask you a big favour!can you help me solve this problem if you can!http://www.tomshardware.co.uk/forum/248212-12-platinum-msdos-problem
thanks in advance!!!
Master-de-bater
More Information
Did you make the floppy a bootable floppy? You know, by right clicking the floppy disk and hitting format, then hit create a MS-Dos bootable drive or something.
More Information
yes i know.it has successfully build a bootable floppy but the motherboard just wouldnt load it up.how do you flash your vga bios anyway?
Master-de-bater
More Information
First make your floppy drive the first boot priority. Then when it asks for the command, you type something like 'nvflash -2 -3 -4' or somthing. Sorry, not too clear on this, I have never done a bios flash.
More Information
alright mate!thanks for that.i still cant load up the ms-dos
Profile: member
More Information
Hey, was wondering. how have u gotten ur mem up2 2070? rivatuner only lets me up2 1460mhz for memory clock?
Master-de-bater
More Information
2070 effective vs. 1035 noneffective. They are the same speed.
Profile: member
More Information
Oh ok cheers, did wonder about that :)
More Information
what speed did you get yours upto?volt modded??
Add a reply
Google Ads
