SSD - The Performance Upgrade of the Future
Hey, i have an AMD Athlon 2400+ when i enter the option of the CPU SPEED in the BIOS, i see 2 options, 1- 2000mhz 2- 2666mhz and in the default it's in 2000mhz.. if i put 2666mh will this damage the CPU? thx
anyone?
I suspect it will if you are running stock cooling. Too much heat. I could be wrong tho, not familer with that CPU tho.
Is that the only option you get in the BIOS?
You need to adjust the motherboard settings as seen in the following link: http://www.ocworkbench.com/hardwar [...] v266p6.htm I suggest you also read the guide on how to overclock an AMD cpu at the top of the overclocking forum.
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
