12 Computers For Christmas
I am thinking about installing Vista Ultimate 64. I currently OC my E2160 to 3.2GHz with 2x1MB Ram. The memory OCs well also. 1. Will I have to up the voltage if I add (2) more sticks of 1MB Ram? 2. Will I have to increase my NB voltage? 3. Will it be noticeably harder to keep my OC stable? 4. Should I nix the 4 stick plan and score some 2x2? Thanks.
1.) Perhaps. Run Prime95 blend test to make sure. 2.) No, unless you want to OC further. 3.) Because of the new OS? Or the extra ram? Either way, as long as if it passes Prime95 small FFT and blend test it's fine. 4.) Nah, unless you wanna OC the ram real high.
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
