Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Fan control and the Antec Tru Power Trio and fan noise in general
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Fan control and the Antec Tru Power Trio and fan noise in general
Profile: addict
More Information
As some of you may know, I am getting new goodies. See this thread
http://www.tomshardware.com/forum/246270-28-case-toys
I like my pc to be as quiet as possible. The sum total of my fan experience is the Thermaltake Silent wheel which says its dBA is 16 and an Apevia which says its dBA is 29.6
The Apevia are noisy, the silent wheels are, silent.
I just purchased (somewhat impulsively) 5 140mm Yate Loons which says its dBA is 29.6 (ISO certified)
Are they going to be as loud as the Apevias at same dBA? or does size matter?
I also have the Antec Tru Power Trio 650w with the fan controller. I have no clue how it works. Do the pins just under volt the fans which helps keep them quiet?
Thanks
E8400@4.0(9x445)Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x1GB Crucial Ballistix,CM690 w/ 5x140m 3x120m fans,Idle 35c load 55c-Corsair HX620w
Related Pr oduct
Profile: old hand
More Information
depends really, if they are big they may spin slower if they are actively controlled but most like they will be louder thatn previous quiter fans
Profile: addict
More Information
Yes, a decibel of sound will not change from one type of fan to another, it's constant.
E8400 @ 4.0 | Asus P5NE-SLI | 4x1g Tracers 800MHz @ 889mhz | 2x160 Raid0 | 1x160 storage | LiteOn DVDRW
SB Audigy 2 ZS | EVGA 8800GTS 512 @ 756/1890/1080 | Corsair HX 620W | Dell 2407 WFP
Add a reply
Google Ads
