Tom's Hardware > Forum > Motherboards & Memory > Memory > OCZ PC2-6400 Plat rev2 + Corsair Dominator RAM problem
Forum Motherboards & Memory : Memory - OCZ PC2-6400 Plat rev2 + Corsair Dominator RAM problem
I use a XFX 650i Ultra motherboard and I cannot use both ram modules together. I have tried "underclocking" both modules however Windows Vista will not boot up (blue screen of death). However if I use one or the other it works perfectly.
To be more specific:
OCZ 2GB PC2-6400 EL Platinum XTC Edition Rev. 2 Dual Channel DDR2 Kit (2 x 1GB)
and
Corsair 2GB XMS2-6400 Dominator TWIN2X Dual Channel DDR2 Kit (2 x 1GB).
Sponsored Links
This is not uncommon as mixing memory can be unstable. Since you are trying to use 4 modules you will need to increase the voltage to your memory controller, aka NB.
------------------------------ Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
To see if the problem is incompatibility between the two module types, try installing 1 module of the OCZ and 1 of the Corsair and see what happens. If that works fine, your issue is likely the 2nd mentioned by Yb.
Reply to Mondoman
There are 721 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
