Tom's Hardware Forums » Motherboards & Memory » Memory » Help with Ram: A-Data review and compatibility
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help with Ram: A-Data review and compatibility
Profile: stranger
More Information
Ok, sorry for all this thread making. I'm back in the market in developing a better P.C since I had the chance to score on a quad q6600 G0 on black friday
Recently i just bought these A-data ddr2 800 extreme edition CL:4-4-4-12 2t
http://www.newegg.com/Product/Produc...82E16820211174
ok, so lately i've been kind of contemplating because on fatwallet.com, some one posted this deal
http://shop1.outpost.com/product/520...H:MAIN_RSLT_PG
and im wondering whether i should return the a-data's and get those instead or...
buy another 2 dual kit memory set? because I want 4-6gb of ram in my computer. My purpose for the new computer is to put a MAC OS X leopard on there too as well, ill be doing some 3d applications, and probably gaming.
Soo my questions are:
1. should i return the a-data and get the one's from fry's?
2. should i buy the one's at frys and combine them with my a-data? will they jeopardize any performance of either ram?
3. buy another set of 2 GB (2x1GB) of ram ? and if so, what kind of ram should i combine it with my a-data to perform at compatible speeds? such as combine my a-data with ballistix? or buy another set of a-data ram?
4. anyone used these a-data ram before? i couldn't pass up on 2 gb ram for 26.99
info needed, not very Memory savvy.
here is the link:
^ that's the ram that i got now.
should i go for another 4-4-4-12 timings with the same voltage?
so if i got two different brands but at the same timings/voltage, how will the overclocking be done?
these are the ones that i was thinking of returning my A-DATA extremes for these
i want to have at least more than 2gb of ram.
Can I add 4gb of ram with my 2 gb A-DATA? if that's the case, what would be the best match compatibility?
Related Pr oduct
Profile: Eternal Poster
More Information
None of the links are working, they maybe links to the log in area.  Try copying the link for the specific item in the area you don't need to log in to get to.
Add a reply
Google Ads
