- Insert the GRAND THEFT AUTO: San Andreas DVD into your DVD-ROM Drive.
- If Auto play is enabled, the Launch Menu will appear otherwise use
Explorer to browse the disc, and launch the INSTALL.EXE program.
- Select the INSTALL option to run the installer.
- Agree to the License Agreement.
- Choose the install location:-
by default we use "C:\Program Files\Rockstar Games\GTA San Andreas"
- Choose Install type - the two options are :-
"Play Radio Stations from DVD" (requires 3.6 GB of Hard Drive space)
"Play Radio Stations from Hard Drive" (requires 4.7 GB of Hard Drive
space)
- Once Installation has finished, you will be returned to the Launch Menu.
- If you do not have DirectX 9.0c installed on your PC, then we suggest
launching DIRECTX INSTALL from the Launch Menu. This will require
you to reboot your computer after installation has finished.
