Odd Axim X50 Problems
Forum Smartphones & PDAs : Handhelds General - Odd Axim X50 Problems
Archived from groups: comp.sys.handhelds (More info?)
I am having two odd problems with a new Axim X50:
First, the wifi. The 802.11b works fine at home, but not at work. At work,
the X50 finds two networks with the same name and swaps back and forth
between them. It is one network with multiple wireless routers. The signal
is good on one and bad on the other so that the unit bounces back and forth
between good signal and no signal. Of course it is unusable this way. Any
ideas?
Second, the sd card. I can put the sd card in my desktop computer, transfer
a few files and when I put it back into the x50, it does NOT see the new
files. I have tried "show all files" and "refresh". If, using the x50, I
create a new directory and copy some existing file on the card into the new
directory, the x50 will magically see the new files in the root of the card!
Any ideas on this one?
Thanks
Charles
Sponsored Links
Thu, 26 May 2005 13:19:15 -0400, Charles Perry:
> Thanks
> Charles
Is the device switched on when you insert the card? May be the event
that informs programs about changes of peripherals doesn't fire
because it is switched off.
Gruß | Greetings | Qapla'
"All I ask is a tall ship and a star to steer her by."
http://www.stud.tu-ilmenau.de/~frst-ii/
Reply to Anonymous
Tom's Hardware > Forum > Smartphones & PDAs > Handhelds General > Odd Axim X50 Problems
There are 916 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
