News
Thermaltake's Combines PC Case With Fridge
Published on September 23, 2008
Thermaltake's Xpressar RCS100 PC cooling system combines a computer case with a refrigerator Read more
Tclink demonstrates car-radiator based cooling system
Published on June 05, 2006
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
CES 2006: Samsung's programmable high-tech refrigerator
Published on January 05, 2006
CES product intro Read more
Corsair intros water cooling kit
Published on January 28, 2005
Memory company Corsair announced a water cooling kit. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Published on December 29, 2008
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
  Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » Fridge as a chassis cooling system
Word :   Username :
Bottom
Author
 Thread : Fridge as a chassis cooling system
Profile: newbie
More Information
Hello again!
I had an idea on using a fridge as a case. I think it's a great idea, since it produce alot of icecold air around the components. Now, my idea was to cut out the side on the chassis, where you put the components on. And put it in the fridge/freezer. And maybe cut some holes in the front, and put some fans that can push out the air. And the fridge push cold air in. But I was thinking, does it get muggy in there? If so, isn't that dangerous for my hardware?
(Edit: A colleague at my work, said that it won't get muggy inside the fridge, if I keep it closed all the time. If I open the door, it'd can get muggy).
If not, I was thinking of setting a watercooling in the fridge where the freezer itself is. So it gets extra cold, and will cool down my components even more.
The noise? Yeah, it'll be really noisy, but I don't care 'bout that. Even though I'll set some Nexus DampTek Noise Absorption Material around the freezer/fridge inside (maybe outside too? If that helps).
Noise Reduction:
- DynaMat
DynaMat is actually for cars. But in great use for this too. Reduce vibration and noise.
- DampTek
This will reduce noise.
I will cover the walls inside with these materials. Maybe on the outside too?
Fans:
- Akasa Crystal 80mm LED Fan
Fan speed: 2500 RPM
Airflow: 28.76 CFM
Noiselevel: 27.45 dBA
- Akasa 120mm LED Fan
Fan speed: 1700 RPM
Airflow: 59.05 CFM
Noiselevel: 29.75 dBA
- Delta 120mm EFB1212SHE
Fan speed: 3700 RPM
Airflow: 141.96 CFM
Noiselevel: 52.5 dBA
I'm not using the fans for cooling, but to move the air around in the chassis. I'll be using between 7 to 10 fans for optimal airflow around the chassis. And some extra cooling?
Well, I'll put some fans on the heatsink though, for extra cooling.
My colleague said that I won't be needing to cut holes in the frontdoor and put some fans there to push the air out. The fridge itself will do the job.
The heatsink system:
Motherboard: Thermalright HR-05/IFX
http://www.thermalright.com/new_a_ [...] 05_ifx.htm
CPU: Thermalright Ultra-120 Extreme
http://www.thermalright.com/new_a_ [...] VzaWFzdA==
VGA: Thermalright HR-03 GT
RAM: Thermalright HR-07 Duo
MOSFET: Thermalright HR-09 S/U (type 1)
I don't know if I'll be using only heatsinks, or a combo of watercooling and heatsinks. Maybe you guys got experience enough to tell me what would be best to use. My opinion is to use heatsink only. Since the cold air that flows around will cool down the heatsink even more. But when I'm thinking of to connecting the watercooler to the freezer, I'm thinking that would be even more efficient.
The watercooling system:
- Swiftech H20-220 Ultra + Water Cooling Kit http://www.xoxide.com/swiftech-h2o [...] -plus.html
If I'm gonna use the watercooling. Then it'll only cool down the CPU, VGA and maybe the MB? And use heatsinks on the rest. But I was thinking, maybe I can make the fridge itself cool down the watercooler, so I get icecold water and air!
Chassis:
http://img404.imageshack.us/img404/8085/341224eg8.th.jpg
HxWxD: 415 x 190 x 445 mm
Case size: Mid Tower Chassis
Price: 58$
Fridge:
http://img509.imageshack.us/img509/1471/srg118ou0.th.jpg
HxWxD: 836 x 453 x 495 mm
Weight: 25 Kg
Energyclass: Class B
Noise: 36 dBA
Price: 289$
Freezer:
http://img509.imageshack.us/img509/846/321646gc2.th.jpg
HxWxD: 850 x 550 x 600 mm
Weight: 45 Kg
Energyclass: Class A
Noise: 45 dBA
Price: 386$
So what do you guys think about this solution for chassis cooling?
Kind regards,
Nymph.
Message edited by xzec on 03-04-2008 at 01:17:53 PM
Related Product
Noob? Currently on Sabbatical!
Profile: Honorary Poster
More Information
Nuts, I Like it, let me know how it works out! Cant you just set your res in there and chill your coolant that way? Prolly need a double pump and semi-long hoses, but whats new??
Like I said, I Like the Idea, try it out and let me know!!
--Lupi!
Profile: newbie
More Information
--Lupi!
Yeah, I could do that. But if the watercooling was going through the freezer, so the water gets even more cold (if possible), then I'll try that.
I let you know when I'm finished. I'll post some pictures and explain in detail how I did it.
Kind regards,
Nymph.
Profile: journeyman
More Information
to much internal condensation will occur, water and electrics don't mix eh
Plays with his WEI
More Information
Quoted For Truth
A slightly better idea may be to set up liquid cooling and put the radiators in the mini-fridge. But then (1) you'd still have condensation issues because outside air would condense on the cold coolant lines, collect and drip on your components. So you *will* have to devise some effective means of preventing that from happening. And (2) refrigerators are not designed to cool items which continuously and actively produce their own heat. You may (or may not) be able to get away with it, but know that your 'fridge will be forced to run harder than it's designed to.. (overclocked 'Fridge!?!?!)
Message quoted 1 times
Message edited by Scotteq on 03-04-2008 at 04:24:00 PM
The more I read the forums, the more I feel that a number of individuals would be well served by skipping their next GPU purchase in favor of a little "Stress Relief" from the local Working Girls
OddJob's side-kick!!
More Information
This is basically what a phase cooler is, just use that if you have too.
Na na na na na na na na HATMAN!
Profile: enthusiast
More Information
This very config idea has been contemplated by many people numerous times over the years. But it is still a bad idea. The reason is that the compressor equipment ina refridgerator is not built to handle a constant source of heat. It is in fact built to cool something down that will stay cold. Not to cool something that will continuously dump heat into the fridge. It will work for a short time, but will fail quickly. And when it fails it just might cause your system to over heat and fail. I recommend if you want to go with something similar look at a Vapo-Chill case or cooling unit.
-ouch1
Profile: nimble knuckle
More Information
I have to give you credit for your persistence.....
Condensation on the tubing would be no problem, you can get tubing with neoprene wrapped around it like the specialty tubing made by Swiftech. It comes wrapped in neoprene and smartcoils.
However, refrigerators/freezers aren't designed to run 24/7. You are still better off setting up a chiller system either by buying one already made or making one yourself with something like this:
http://www.overcool.com/Exec/produ [...] m_id=29988
Then, there is phase change of course.....
Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Master-de-bater
Profile: Eternal Poster
More Information
You may end up freezing the HD, losing all data.
Depending on how long you use the pc, the fridge won't last very long.
...what's wrong with plain old air-cooling?
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Profile: newbie
More Information
Scotteq wrote :
Quoted For Truth
Haha, yeah, something like an "overclocked" fridge, but hey, I've been convinced from not doing this. I posted the same thread as this in another section. And everyone there convinced me NOT to try this. Even not for fun; joy-killers... :P
But I still maybe try to do this, and maybe try to find a solution to make this work. I've got some friends who are high-skilled engineers, I can ask them to help me to find a solution for this.
IF there where a solution for this, I will begin case modding on it too. Make this chassis real special :).
Kind regards,
Nymph.
Profile: newbie
More Information
Oh, okay.
Nothing wrong with the good ol' air cooling, it's just I want to try to have cooled air. But it's the damn condensation issue. BUT! It's possible to prevent the condensation, by having the fridge always sealed. I can only open the door, when everything is shut down. But how can I make the fridge handle 8 hrs constantly heat? It'll maybe handle 5-6 hrs, if modified. Maybe there is a solution for having air coming in and out, without any condensation problem. Like, modify the freezer inside the fridge, take it out, and just use it in a normal chassis. And make it cool the air with low humidity. But that'll maybe be some heavy, advanced engineering. Oh well, I keep my hope for a solution.
Kind regards,
Nymph.
Plays with his WEI
More Information
Kind regards,
Nymph.
Nymph - Just to be clear: I'm not saying the idea isn't Cool (sic). Just that a Mini Fridge isn't the way to go about it. As pointed out above - A Vapo~Chill setup would be better for this particular application.
"DUUUUUDE!!!! YOU BOUGHT A...... Maytag!?!?!?!? :pt1cable: :lol: :pt1cable: :lol: :pt1cable: :lol:
Resident Jerk
Profile: Faithful Poster
More Information
xzec wrote :
Oh, okay.
Kind regards,
Nymph.
If you open the door and let ambient air in it will condense on anything below the dew point.
Closing it and running the fridge will dehumidify and lower the dew point below the ambient temperature within the fridge.
The main issue I see is heat load. Fridge's are not designed to deal with a constant heat load inside. Just buying a fridge and making it work might NOT work. It might not be able to keep up and end up overheating the compressor, or any other number of issues.
As said, chiller or the likes.
TeamBAG Member
More Information
n°1748503
03-05-2008 at 11:21:06 PM
