Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Nvidia > 8800gt and Thermaltake Toughpower Issue
Forum Graphics & Displays : Nvidia 8800gt and Thermaltake Toughpower Issue
Just put toghether a new system with an evga e-geforce 8800gt superclocked, whenever I boot the system I get the nvidia sentinel message "not receiving sufficient power." So I made sure all the power cables were plugged in, and the pcie cable was securely fastened to the card, still same error. So I tried using the 2 molex to pcie adapter that came with card, still same error. So I unplugged the power to everything except the mobo, cpu, boot drive and 8800gt, still same error. Checked voltages on PSU, and they are fine. So I'm not sure what could be causing this error.
System Specs:
Gigabyte GA-P35-DS3P
2x1GB Crucial Ballistix DDR2 800
Q6600
EVGA E-Geforce 8800GT
Thermaltake Toughpower 650w (modular cables)
WinXP Pro 32-bit
Anyone have any suggestions? Thanks!
-Jon
Reply to thatonejonguy
Have you tried the VGA card in the other PCI slot? Do you also have the additional power plugged into the board? Its a power connector up near the top right part of the board where the memory goes.
Reply to marike
I think ive herd that 8800gt's don't work with thermaltake thoughpower psu's, your not the first one this happened to.
http://www.tomshardware.com/forum/ [...] e-problems
There was a post and the guy had the same problom, and a link to a sight were it said soem 8800g'ts dont work with some toughpowers.
------------------------------ P4 3ghz Ht| Intel D865PERL| pc3200 1 (2x512mb)gig of ram 400mhz, 2.5-3-3-8| 80 gb Seagate Barracuda Hd, 300gb WD HD| Asus 7600gs| 1x Lg dvd reader/cd burner| 1x LG dvd burner 300w psu.
Reply to smokedyou911
I have a 8800gt running fine with a thermaltake toughpower 600w PSU.
Only in XP tho but hats due to my motherboard I think.
Reply to ukscotth
Scott, then your one of the lucky ones. http://www.google.ca/search?hl=en& [...] arch&meta=
There are 1871 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in these cards is only the factory OC right?
By fantastik250, 1 hour ago:
I should say that is the only difference.
Best offers
Top experts
