Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-P35-DS3L USB Flash Drive Boot problem.
Forum Motherboards & Memory : Gigabyte GA-P35-DS3L USB Flash Drive Boot problem.
I just built a computer with GigaByte P35-DS3L Motherboard, and used Norton
Ghost to create a bootable USB Flash drive. But it seems that GigaByte P35-
DS3L Motherboard won't boot from the USB Flash drive. The light on the Flash drive
flashes, which indicates some access.
That USB Flash drive can be boot up without any problem on another computer.
Here are some of the my BIOS configuration:
Advanced BIOS Features:
Hard Drive boot priority: Kingston Flash Drive 2.0, West Digital Hard Drive.
First Boot Device: I tried Hard drive, USB-FDD, USB-ZIP, USB-HDD, USB-CDROM. None of them works.
Integrated Peripherals:
USB Controller: Enabled
USB 2.0 Controller: Enabled
USB Keyboard Support: Enabled
USB Mouse Support: Enabled
Legacy USB storage detect: Enabled.
Hope someone can share some expertise on it.
Thanks.
Reply to regex
Did you ever figure this out? I'm still having troubles with it... I know that the flash drive is a USB-HDD, but it won't boot (even though it works on other systems). It just skips right to the internal Hard Drive and boots windows...
Reply to ArmoredCavalry
Change boot priority in BIOS. I have the same motherboard and can boot in to Linux via 2GB Corsair Voyager USB.
------------------------------ http://farm5.static.flickr.com/4113/5052517574_1d0ebc741b.jpg
Reply to Shadow703793
I've put USB-HDD first it the boot order, but then it just sits at the post screen, and doesn't boot from the flash drive. :(
- 0 +
Shadow, what did you change the boot priority to? there are a number of choices that seem "right". USB-FDD, USB-ZIP, USB HDD... not sure which is the 'right' one.
------------------------------ Q6600 G0 @ 3.5GHZ | GIGABYTE GA-P35-DS3L | ANTEC P182 | XFX 8800GTS (G92) 512MB | THERMALRIGHT 120 ULTRA EXTREME | CORSAIR 520HX | PATRIOT EXTREME 4GB (2 X 2GB) DDR2 800 | SEAGATE 7200.10 | SAMSUNG SH-S203N |
VISTA 64 HOME PREMIUM
Reply to althius
Wait, how do you even make the USB flash drive bootable? I was told to format it under Windows with a FAT partition. I wanted to update my bios from it, but I would go in the flash utility in the ga-p35-ds3l and it would only detect the floppy disk. I ended up using the floppy.
Reply to nforce256
- 0 +
I had the same problems with my Lexar usb flash drive, which was already formated in FAT. LSDMEASAP recommended re-formating in FAT, which solved my problems with all the default values set in the bios for usb.
The default value in bios is for a floppy drive even if one is not attached. With this setting my flash drive showed up as floppy drive B in Q-Flash. No need to set HDD order or anything.
Reply to Merman
I got my sony usb to work with backpack 3 by changing the hard disk priority. This option is on the top of the list in the advanced bios menu, just above the boot order. There was an option to boot from the usb-hdd before the hard drive.
Reply to brandonros
I just want to reiterate what brandonros said.
Get into BIOS settings
Hard Drive Boot Priority
Then move the USB drive up to the top.
The program I used to make my USB drive bootable was HP USB Disk Storage Format Tool. Remember, you won't see the files on the USB drive unless you go to folder options and set it to show hidden files and system files.
how to boot from usb thumb drive
how to make bootable usb thumb drive
Message edited by bernardino on 08-07-2008 at 08:39:31 AM
Reply to bernardino
note:you have to open your computer case for doing this if u want to then u can proceed!!!!!!!!!!!
you will be able to boot from flash drive if you follow these steps:-
1) open you computer case
2)remove the sata cable of your hard disk (if using pata hard disk then remove pata cable)
3) then try to boot with your flash drive using boot option
may it helps u because i am successful in doing this method
thanks
Reply to sonu singh_48
After pressing F12 while booting your computer, you will find "+" symbol just beside 'HDD' option , expand the "+" you will find your USB Flash right there.
Reply to k-elshemary
I have GA-A75M-UD2H
I have the same USB Boot Problem.
I habe ce. 10 USB-Sticks -
some of the old TakeMS-2GB and 8GB and one MicroSD-USB-Adapter boots well.
No ScanDisk - no the other SD-USB-Adapter no ADATA-Stick
no boot from the rest.
Sipmle not Listed F12 after + in HDD-Drives ---
I have changed many options in BIOS -- even tryed Default settings -- even Reseted BIOS by Jumper an Battery -- Even have tryed various Formatprograms for Formatting FAT32...
Same Problem after BIOSupdate.
All Sticks boots well from other computers.
Reply to Anonymous
There are 1879 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 6 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
