Tom's Hardware > Forum > Storage > DVD/CD Writers > Data Burn Problem
Data Burn Problem
Forum Storage : DVD/CD Writers - Data Burn Problem
I have a large folder of data (mostly Office files) that I have attempted to burn on 2 different computers with different programs. The data transfers fine from disk to USB drive. On both PCs the burn seems to go fine, but when I put the DVD in the other computer it doesn't read. What could I be doing wrong?
Sponsored Links
What type of DVD media are you using? Are you sure the second computer is a DVD drive, and is is speced to be able to read the DVD media you are using? Most drives can read DVD+RW, some cannot. Newer drives can read DVD-RW, but there are lot of older drives out there that cannot.
Anyway, I'd say this is your problem. You are burning in a format that the second drive cannot read.
Reply to jitpublisher
I'm using HP dvd+r 6.5 GB data disks.
The reading drive is DVD-RW. When I put the disk in it turns the icon into "CD Drive".
Reply to graffspree
This is really a pretty common problem. Where I work, we burn a lot of DVD's for training and educational purposes. Every so often we get a call from a trainer somewhere who complains that the DVD's sent to them do not work. So we burn them a new set at DVD- and send to them. That seems to do the trick.
Whats good free burning software for data disks? I don't really burn anything else.
Reply to graffspree
Nero Express works just fine for me. I got it free with my LG drive.
6.5 GB disks? Maybe your reading drive only recognizes 4.3 GB single-layer disks.
Message edited by aevm on 07-17-2008 at 04:23:52 PM
Reply to aevm
ImgBurn.
http://imgburn.com/
Message edited by skittle on 07-17-2008 at 04:26:20 PM
------------------------------ macgirlfriend:
"Hey I don't get you people, the people on insanely mac were so much nicer"
Reply to skittle
ImgBurn did the trick! Thanks all.
Reply to graffspree
Maybe you must "Finalise the disk" after burning to make sure it can be read on another computer.
Reply to freeduck
There are 815 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
