I know there are many threads regarding what I need done. I need to build a new system, My mother will be purchasing the gfx card (8800GTX). My spending limit is around $1300 a lil more or a lil less. I need something that will run COD4 at max settings, I want performance. I'm only looking for 320GB HDD. Not sure to go with quad or c2d.
I want to run Vista 64bit, and I also want 4GB dual channel RAM. Please help me choose the right things. Any help is appreciated.
Definitely get the quadcore instead, also all 88xx series will play COD4 maxed out, well if u have the money, go for the GTX, however 8800GT performs closely to a 8800GTX but it runs more hotter than a GTX, also in very high resolutions like 1920x1200 or 2048x1536 8800GTX performs better than a GT
Q6600
ASUS P5K-E or GIGABYTE P35 DS3R or ABIT IP35 PRO
4GB DDR2 800 RAM with good timings (if u want to OC) like 4-4-4-x or lower
Either 8800GTX or 8800GT
Seagate Barracuda 320GB 16MB
OCZ STEALTHXSTREAM 600WAT PSU or higher
THERMALTAKE ARMOR case or any case with good airflow
------------------------------Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
PLEASE PLEASE PLEASE!
I desire your suggestions, if you guys have any please let me know.
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
Item #: N82E16827106072
Return Policy: Standard Return Policy $35.99
Thermaltake Armor Series VA8000BWS Black Aluminum / Steel ATX Full Tower Computer Case - Retail
Item #: N82E16811133154
Return Policy: Standard Return Policy $40.00 Mail-in Rebate $149.99
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822144701
Return Policy: Limited 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $14.992 Year Service Net Replacement Plan -- $19.99 $69.99
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply - Retail
Item #: N82E16817341002
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.992 Year Service Net Replacement Plan -- $39.99 -$10.00 Instant
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPK - Retail
Item #: N82E16820231148
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.992 Year Service Net Replacement Plan -- $39.99 -$30.00 Instant
$179.99
$149.99
EVGA 122-CK-NF63-TR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
Item #: N82E16813188019
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.992 Year Service Net Replacement Plan -- $39.99 $169.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Item #: N82E16819115017
Return Policy: Processors (CPUs) Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.992 Year Service Net Replacement Plan -- $59.99 $279.99
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler - Retail
Item #: N82E16835118019
