I have a SC and I overclocked it to SSC speeds and I was getting temps right around 50c with the fan at 25%. I saw it go as low as 44c with the fan at 100%. I think it was in the high 60's after a game.
Ambient temps were low.
Maybe check the fan/heatsink to see if it's mounted properly.
My 8800GT EVGA Superclocked is at Fedex right now so I can't really say...
But I can say that my 7800GTX idles at 50C and loads at 95C. I had my fan accidently set down for a week or so it and would throttle itself when it hit 115C in C&C3. That was pretty noticeable =)
Anyways, its still had no ill-effects whatsoever... An XFX 7800GTX running at 515/1350 still like a top. Will make a nice card for my girl's photoshop rig.
I'm sure newer cars are ever so slightly more durable when it comes to heat.
*EDIT*
I will say that card PCI slot placement and case airflow will make a huge difference in temps. Removing my TV-tuner results in a 20 degree LOWER load temp for my 7800GTX. So thats a 75C versus 95C.
Message edited by DiamondWraith on 11-19-2007 at 05:14:06 AM
My OC'd 8800gt is about the same as yours, 57 idle and 87 under load. People seem to say that's fine for a GPU. I'm still going to get a Duo Orb cooler for it though so i can OC it a bit more.
------------------------------Q9450@3.2GIG,8800GT Gigabyte P35 DS3P, 2X2 Gig OCZ Reaper HPC 1066,
Vista Ultimate 64 bit
Reply to tricky trees
