Yes No
Ads
Icon display problems
Forum Windows XP : Configuration & Customization Icon display problems
Hello, I used the set up feature to choose a program to view the icon, using file explorer. Now, I can't get the icons to display anything but a set image for paintbrush. I use Windows XP.
Reply to emeskay
Interesting. Can you tell me in more detail the process you used to set the program? I want to better understand what was done so that we can find a solution for you.
Cheers!
Reply to digitalprospecter
Thanks for the response. I've been out for more than a week, so it took me a while to get back to you.
Much to my suprise, my computer was upgraded to Office 2007 and I got a new cpu. The icon problem disappeared, because they used an earlier version of my desktop to load onto the new cpu.
However, since you asked, from File Explorer, I clicked on Tools/Folder Options/File Types, and then deleted the .ico extension (this was an accident). Then I added it back in, and it automatically picked a type of icon to display.
I couldn't get it to not pick an icon.
Reply to emeskay
Tom's Hardware > Forum > Windows XP > Configuration & Customization > Icon display problems
There are 1940 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 8 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
